Extractors for Toyota 3F motor
Submitted: Monday, Oct 11, 2004 at 11:17
Rod E B
I have just read the article in the Decemder issue of Caravan and motorhome which sayes that fitting extractors to a Toyota Landcruiser will increase the power by 13.5% and reduce
fuel consumption by 15%
I have a 1985 landcruiser , petrol , with a 3F motor
Has anyone got experience with doing this if so
did it work
did it increase power
did it reduce
fuel consumption
how much did it cost
Rod
Reply By: Glenn (VIC) - Monday, Oct 11, 2004 at 11:21
Hi Rod,
I cannot answer your questions, but I would be interested in the responses. I too have a 3F engine, and would appreciate assistance in reducing the
fuel economy.
79684
Reply By: Wok - Monday, Oct 11, 2004 at 11:40
Rod,
That was my original donk...it improved acceleration....
fuel figure was 6.5 - 7.5km/l with half ton + lightly loaded roof rack (no swag!), 2200rpm max.
The biggest improvement I got was fitting an MSD5 (I think thats the number?) and an Allison electronic points.The figure above is for that combination.
I can't remember the $......1986!!!!!!!!!!!!!!!!
The engine braking was worse ( I remember that much!)..IMHO the Allison & MSD was a better investment.
79690
Follow Up By: Rod E B - Monday, Oct 11, 2004 at 12:16
Sorry I do not what a MSD5 is
Are Allison electronic points fitted by an auto electrician
Cost , ball
park , say to compare with the $ 600 for extractors quoted in the thread
339069
Follow Up By: Wok - Monday, Oct 11, 2004 at 13:06
MSD = Multiple Spark Discharge US made, used often in dragsters
Allison came from TANDY in '86, Autobahn carries spares, don't know if the unit is still available....Gooogle?
Very easy to fit both units...once the timing is set on the distributor it doesn't change.
With the mag test giving 13.1l/100k it would be useful to know the load carried etc details...details....details!
339086
Follow Up By: Wok - Monday, Oct 11, 2004 at 13:29
Just did a Goooogle......things have changed! Allison >>> Crane
Hope it helps
339091
Follow Up By: Rod E B - Monday, Oct 11, 2004 at 13:37
1995 80 series 1hz diesel
no load details
no further details ....details....details
339094
Follow Up By: Wok - Monday, Oct 11, 2004 at 15:25
Mark me confused!...the tests were done on a 1995 80 series 1hz DIESEL? I have been under the impression that diesels needed some back pressure to function efficiently and that 'full flow through' exhausts wasn't a good idea........another myth?
Those figures won't translate to 3f.
My links to Cranecams & MSD didn't come out....can't figure out the hyperlinks........the $ are >>>>>>>>>>>>budget...
339112
Reply By: Truckster (Vic) - Monday, Oct 11, 2004 at 11:42
So all the did was fit extractors, no tuning, no complete exhaust change over, no new muffers?? Just extractors.
13% more power? AND a massive 15% better
fuel?
You can make figures do anythign you want really, drive 'slower, or not as harsh', etc..
Amazingly you rarely hear of people doing mods and saying that they did nothing.
Extractors alone are about $400-600 depending on brand.
IFIHTB...
79691
Follow Up By: Topcat (WA) - Monday, Oct 11, 2004 at 15:01
I agree with Truckster on those figures. My first Troopy was an 83 FJ45 to which I fitted a 3F motor with Genie extractors & electronic ignition. The performace did improve, but only by about 5% on the economy (I think the best I got was an extra 1-1.5 km/litre depending on which way the wind was blowing) The acceleration & pulling power on the hills did show a mark improvement after the extractors were fitted, but without doing a dyno test I couldn't tell by how much.
339105
Reply By: Uppy - Member - Monday, Oct 11, 2004 at 12:06
Hi Rob,Im adding extractors,along with a 3inc exhust pipe,all up and fitted $700 as quoted,by Greenwood motors ,
Perth.This is on
mine GQ efi 4.2.
kind regards uppy
79695
Follow Up By: Rod E B - Monday, Oct 11, 2004 at 12:13
would really like to know what happens ,
can you please email me when you have some results
339068
Follow Up By: Uppy - Member - Monday, Oct 11, 2004 at 12:50
Rob ,I will let you know as soon as it is done,should be next month.
regards uppy
339079
Reply By: Rod E B - Monday, Oct 11, 2004 at 12:11
Please don't kill the messenger , the article was over 4 pages , but a summary below
The article said they fitted extractors and a free flow exhaust .
power figure was from dyno tune
revs standard system new system
1500 32.4 hp 38.2 hp
2000 43.6 hp 49.6 hp
2500 53.8 hp 61.4 hp
3000 67.4 hp 76.8 hp
fuel 15.4 L/100km 13.1 L/100km
fuel economy was over 2 tanks petrol , general use
79697
Reply By: Member - Andrew(WA) - Monday, Oct 11, 2004 at 14:38
Rod
My 1st 4x4 was a mid wheel base 1985 cruiser with the 3F. I had it on gas too.
I put extractors, a 2.5 inch exhaust with a straight through turbo muffler.
The first thing I noticed was how much quieter and smoother the engine was at idle. It drove far nicer and smoother in every respect.
I did not do any performance tests on a dyno or anything like that but it was definately a better car for it.
I never noticed any increase or decrease in
fuel consumption. I just remember it being a thirsty bugger! most of the time.
Mine cosy around $450 fitted back in 1993. I strongly recommend the conversion.
79720
Reply By: Troopy Travellers (NSW) - Monday, Oct 11, 2004 at 20:08
Our troopy has got a 3F engine fitted with extractors, by the previous owner. I average about 15l/100km, seems to go OK , has a nice exhaust burble! When I tried to get it insured, on of the big name insurers told me that they don't insure cars with extractors!
Sparky
79786
