4runner rear suspension lift 1991
Submitted: Tuesday, Oct 12, 2004 at 08:54
hogscar
After inserting heavy duty coil springs, the rear axle moved 7mm to the right. Does anyone have ideas on correcting the sideway movement of the rear
suspension of a 91 toyota 4runner?
Patrols have an after market adjustable panhard rod. Can't find anything for my 4runner.
Reply By: surfv6 - Tuesday, Oct 12, 2004 at 12:46
Since I fitted 80series std rear springs to my surf [4inch lift] found that I too needed an adjustable panhard rod and after searching the 4wd shops found Opposite Lock carry an adjustable rear panhard rod for 1990-95 4runners/surfs [rear coil
suspension]. It is the Tough Dog brand and is visually bigger than the orig and is easily adjustable. Sorry can't remember what price it was but it worked a treat.
79903
Reply By: crackajnr - Tuesday, Oct 12, 2004 at 16:59
if you are handy with a welder you can make a drop down bracket to level out the bar and return the diff to center.thats what i had to do with my terrano after lifting it 3 inches.
79939
