Tow (rope?)
Submitted: Friday, Oct 15, 2004 at 13:03
ThreadID: 17063 Views:3037 Replies:11 FollowUps:3
My snatch strap works very well for the purpose intended.
But after extracting a vehicle (or being extracted) what's the best material to use for a conventional tow back to civilization?
Chain? Rope? Strap? Wire?
All opinions gratefully received.
Boxer
Reply By: Patrol22 (Queanbeyan - Friday, Oct 15, 2004 at 13:21
Hi Boxer
The best is to get the vehicle back to the nearest road where you local roadside assist can take over (eg NRMA RACV RAA etc). Failing that, a fixed or inflexible coupling between the tower and towee like a metal tube with eyelets that can be shackled to the vehicles is next best. Of all the flexible towing items you mentioned (eg chain, rope, strap, wire) I would use the chain BUT only after I was ceretain I couldn't use either of the first two options.
Pete
AnswerID: 80308
Reply By: Rob! - Friday, Oct 15, 2004 at 13:37
Boxer
I too would go for the metal rod/pipe. Not sure about the chain though. Wouldn't you want a little bit of stretch so that you don't jerk the towed vehicle everytime you stop/start. A proper tow rope would be my choice after the inflexible coupling. Just be make sude the driver on the towed vehcicle doesn't drive over it.
R.
AnswerID: 80311
Follow Up By: Rob! - Friday, Oct 15, 2004 at 13:39
that should be-
Justmake sure the driver on the towed vehcicle doesn't drive over it.
FollowupID: 339650
Follow Up By: bushfix - Friday, Oct 15, 2004 at 13:49
ditto Boxer, for the purpose as described "conventional tow back to civilization" I would want a bit of give in the towline if it was not rigid.
from the RTA NSW..
"295 Motor vehicle towing another vehicle with a towline
(1) The driver of a motor vehicle towing another vehicle using a
chain, rope, fabric, strap or wire (the towline) must comply..."
FollowupID: 339652
Reply By: Mad Dog (Victoria) - Friday, Oct 15, 2004 at 13:50
My grandfather used a hunk of rope as my father did for years. A hunk of rope does me as well.
AnswerID: 80312
Reply By: Member - Jeff M (WA) - Friday, Oct 15, 2004 at 14:06
I use an old Truck Winch Strap Tie Down. It's a long flat thick strap rated to 9 tonne.
AnswerID: 80314
Reply By: Davoe - Friday, Oct 15, 2004 at 16:14
anything that wont break. At work we use winch extension straps coz they are rated and they have duel purposees (winch extension,tow strap and bent tie rod straightner but thats another story)
AnswerID: 80331
Reply By: Member -Dodger - Friday, Oct 15, 2004 at 16:23
An short snatch strap will get you out of trouble for a short tow failing that use a bar type tow hitch off the ball of the tow vehicle and chained very tightly and securely to the tow vehicle. But your best option if available is the tilt tray N.RMA type setup. I do not know what the legals are in New South so check when you can.
I am going to visit the RTA site to look after this.
Cheers Dodg.
AnswerID: 80332
Follow Up By: Member -Dodger - Saturday, Oct 16, 2004 at 09:53
See Rule 294 & 295 R.T.A. site.
Cheers Dodg.
FollowupID: 339758
Reply By: bob - Friday, Oct 15, 2004 at 17:12
Boxer
I use a tow rope made by black rat. 4 metres long with 50% stretch with a breaking strain of 12 tonnes.
AnswerID: 80338
Reply By: Member - Camper (SA) - Friday, Oct 15, 2004 at 17:33
A good quality tow rope is the way to go because it has some give. Chain will break if it is jerked hard enough.
Camper
AnswerID: 80343
Reply By: howie - Saturday, Oct 16, 2004 at 00:27
anything that gets you out is suitable.
the hard bit is getting someone who knows how to drive the towed vehicle.
ie doing the braking (if possible) and keeping the tow rope/chain/snatch tight.
towed a mate out of sand once and must admit the snatch strap was best as it had some give in the sand, but on the bitch i would prefer to use the winch strap probably.
AnswerID: 80399
Reply By: Phil G - Saturday, Oct 16, 2004 at 21:50
In the situation you describe, a snatch strap is fine, as it has some give. A 10metre winch extension strap is also fine.
I tend to avoid anything too rigid like a chain, as you put a lot of stress on the recovery points.
AnswerID: 80473
Reply By: Bonz (Vic) - Sunday, Oct 17, 2004 at 22:24
I use a 7 m long piece of rope, poly about 15mm diameter, eye splice in each end. Works fine but you need to have someone in the tow vehicle who knows what they're doing and preferably uhf or cb communications. Just a LOT safer that way
AnswerID: 80610
