1997 gu nissan patrol air con problems
Submitted: Friday, Oct 15, 2004 at 21:10
ThreadID: 17069 Views:3807 Replies:5 FollowUps:0
dear explore oz
i own a 1997 gu petrol patrol wagon and are having trouble with the air conditioning!
have had the air con system fully checked and is in perfect working order
have had the cooling system fully checked and is in perfect working order
my problem is the compressor cuts out at certain times and consequently hot air is blown from the air con.
have had car at many places to repair with no luck
hope you may have some ideas which may help
regards vince
Reply By: Member - Steve G (WA) - Friday, Oct 15, 2004 at 23:04
HI Vince,
how are ya mate,i manage a aircon company and and it sounds like you could have a number of different problems.not knowing where you live you should ring the VASA assoc and find your nearest one and they should give you more help.
cheers steve
AnswerID: 80392
Reply By: Member - Rick (S.A.) - Friday, Oct 15, 2004 at 23:20
here's some suggestions [had similar issuesin my GU]:
1) I wonder if it is the sensors on the bottom radiator tank. Highly likely.
2) Are the cooling fins completely free of dirt & junk? My "clean" rad had 750 grams of very fine bulldust etc in it.
3) ask the question on the patrol forum, which is
http://autos.groups.yahoo.com/group/Patrol4WD/messages
4) if in Adelaide try Highgate Air in the CBD
AnswerID: 80394
Reply By: Vinnie - Friday, Oct 15, 2004 at 23:32
Vince
I had a similar problem with my Mav. I fixed it by cleaning the dirt out of the condensor core, the system needs it to be free of blockages or it just freezes up and wont flow.
Vinnie
AnswerID: 80396
Reply By: Member Eric - Sunday, Oct 17, 2004 at 06:55
more info needed so we can help . What model GU . is it ST or Ti , does it have climate control ? have you been off road ?
AnswerID: 80497
Reply By: V8Diesel - Sunday, Oct 17, 2004 at 18:20
vince76, I've got a '98 Patrol petrol wagon too and it did exactly the same thing during a Pilbara summer. Very boring indeed.
I took it to some mob in Karratha who let a small amount of refrigerant out of the system. He assured me they switch themsleves off because they get overpressurised. Still did it, but to a lesser extent. I'm still not convinced about this.
I also took the radiator out and thoroughly cleaned it to get rid of spinifex, dust build up etc. It was surprising how much crud could still be washed away after blowing it out. Don't forget to clean the aircon unit too. Touch wood, it seems fine now.
AnswerID: 80556
