Fuel Gauge
Submitted: Saturday, Oct 16, 2004 at 13:43
ThreadID: 17084 Views:1925 Replies:6 FollowUps:0
Hey guy's just topped up my tank and noticed the fuel gauge is not moving from empty, and with the TB42 it always is on empty. where do start i priced a new fuel sender $400 dont really want to spend that much could it be some thing else.
Cheers paul
Reply By: Davoe - Saturday, Oct 16, 2004 at 14:51
have you tried giving the dash a firm hard hit?
AnswerID: 80428
Reply By: Utemad - Saturday, Oct 16, 2004 at 17:03
Perhaps the float has a hole in it and is filling up with fuel nstaed of floating on the surface?
AnswerID: 80437
Reply By: Well 55 - Saturday, Oct 16, 2004 at 18:39
It could be a bad earth on the sender unit.
AnswerID: 80442
Reply By: Stevie - Saturday, Oct 16, 2004 at 19:21
what sort a 4wd is it. I know with the 100 series and prado it is a commen problem the only remedy is to replace the sender unit.
AnswerID: 80449
Reply By: Member Eric - Saturday, Oct 16, 2004 at 22:55
ok , go to the sender unit and earth the wire that runs to it . if the guage goes to full . it's the sender unit , if the guage dosnt move , it's the sender
AnswerID: 80485
Reply By: Flash - Sunday, Oct 17, 2004 at 11:16
The sender unit if faulty is easy to replace.
I used one from a Gemini for my aux tank which cost $50 for tank AND sender from the wreckers.
The sender uses the same resistance as the original one and works perfectly on the Patrol gauge. (They're both made in Japan by the same manufacturer)
AnswerID: 80523
