another 3L patrol saga
Submitted: Sunday, Oct 17, 2004 at 18:26
Member Eric
Well , my mate's 3L patrol 2002 model just spat 5th gear , car has done 92,000 kms . How lucky is that lol . I think he is going to listen now and get the extended warranty.
Anyone else come across this yet ?
Reply By: Member - Jimbo (VIC) - Sunday, Oct 17, 2004 at 18:30
2002 model.
Is it not still under warranty? I'm not sure of Nissan warranties but I thought 3 years was the norm these days.
80559
Follow Up By: Utemad - Sunday, Oct 17, 2004 at 18:58
Prob is 3 years 100k. If it wasn't still under warranty then his mate wouldn't be able to go and get the extended warranty.
Also I assume that the 'how lucky is that' statement is to do with it only having 8k to go on his warranty.
339859
Follow Up By: Member Eric - Sunday, Oct 17, 2004 at 20:32
Utemad , your on the ball son
339863
Reply By: GO_OFFROAD - Sunday, Oct 17, 2004 at 20:45
5th gear on the 3.0 is a common problem on those that tow alot, do alot of hwy in 5th gear, or run oversize tyres all the time hwy.
It chews the splines off the main shaft, which is caused by an engine vibration [hence the oil filled flywheel to try and damper the vibration] and this is why its more prevelent on the 3.0 than the 4.2.
The replacement gear has 10mm aprox more spline area where it goes on the shaft, but this doesnt cure the vibration which is the root cause, it just gives more spline area to wear before it goes.
80584
Reply By: Member - Andrew(WA) - Sunday, Oct 17, 2004 at 23:22
Eric
Is this a definate 2002 model. Series II or III?
I have seen the Nissan work
shop manual that talks about the better 5th gear being installed Nov 2001 onwards.
So if this is a 2002 with the 'better' spline from the factory.....MMmm, Problems.
Please check it out.
80620
Follow Up By: Member Eric - Monday, Oct 18, 2004 at 06:46
Defenently built & complied in 2002
339886
Reply By: CHRIS - Monday, Oct 18, 2004 at 07:52
1983/ 60 series Turbo Diesel 248,000 k's, original clutch & 5th gear still A1. Tows a 2 1/2 ton 21ft boat. Oh ! what a feeling.
80640
Follow Up By: Flash - Monday, Oct 18, 2004 at 11:10
1991 GQ turbo Diesel, 298,000 klms and original EVERYTHING incl clutch & 5th gear, etc. etc. etc.. It has not had anything "mechanical" replaced- (except exhaust as the turbo was an add on.) Tows 2 1/2 tonne van and similar weight of boat. You don't only get "that" feeling in your Tojo.
Yes, I'd buy the extended warranty.
339916
Follow Up By: CHRIS - Tuesday, Oct 19, 2004 at 13:44
Yes I do ! and bear in mind that
mine is 8 years older, so stick that up your jumper and smoke it ! (Yes and the Tojo has an after market Turbo and 2 1/2 inch Exhaust). (120 kw).
340111
Reply By: Truckster (Vic) - Monday, Oct 18, 2004 at 10:21
OH MY GOD I WANT ONE SO BAD.. ERIC BUY ME 12 OF THEM MAGIC CHEAP 3.0 GU'S TODAY*
I'm joking, please don't..
80658
Reply By: joc45 - Monday, Oct 18, 2004 at 14:24
For info, the 5th gear in my Series I, Dec 1999 build 4.2 turbo diesel spat the dummy a couple of weeks ago, 115,000.
Same problem as above, so it's not confined to Series II. Never towed anything.
Nissan came to the party under the extended warranty. New mainshaft and 5th gear.
Gerry
80697
Follow Up By: Goona - Monday, Oct 18, 2004 at 21:34
Gerry,
Was there any tell tale
sign it was going to go? I hyave a build date of Oct 1999 with 135000km on the clock.
Nothing wrong yet touch wood.
Goona
340016
Follow Up By: joc45 - Monday, Oct 18, 2004 at 22:42
Goona,
Nope, was loping across the Nullarbor at about 100k/h when it let go with quite a noise.
But previous info has indicated the problem was only Series II from about Mar 2000 build.
Mine was definitely the short spline problem, so it appears that earlier Series I's have it as
well. Suggest you contact Nissan quoting your VIN to see if yours is included.
Gerry
340033
Reply By: Leroy - Monday, Oct 18, 2004 at 15:19
Aren't the 3.0 and 4.2 gearboxes the same? Also wasn't there probs with the 2001 5th gears in both models?
Leroy
80707
Follow Up By: joc45 - Monday, Oct 18, 2004 at 22:43
Leroy, same box. See above.
Gerry
340034
Reply By: AJB - Monday, Oct 18, 2004 at 19:01
My GU spat 5th gear at 143000ks, on the way back from
Broome. Luckily I was only 2 hours from home. Out of warranty but Nissan still covered it. Spline problem. Does heaps of towing (every day about tonne and a half). Anyhow Nissan dealer put what he called a revised part in and away I went. Hope I get a few more k's out of the revised part but who knows or cares!
80741
