3 way fridge, regulator?
Submitted: Monday, Oct 18, 2004 at 19:03
Member - Jimbo (VIC)
It's been so long since I fired up my Chescold 3 way fridge I cant remember if I am supposed to fit a regulator in the gas line. Commonsense tells me I should but I can't find it, which is making me ask myself if it ever existed.
Can someone help please? What type of regulator etc.
Thanks,
Jim.
Reply By: theratt - Monday, Oct 18, 2004 at 19:39
there only very low pressure 2kgs per hr @ 2.8kpa
hope this helps you find it, check your bottle maybe still on it?
80749
Reply By: Aandy(WA) - Monday, Oct 18, 2004 at 19:40
Yes Jimbo, you certainly need a regulator. Not sure of the specs but I think it's the same as goes on a caravan or BBQ. It's a low pressure system on the fridge for sure. Cheers. PS you'd be able to buy a hose and regulator at any
camping shop if you can't find yours.
80750
Follow Up By: Member - Jimbo (VIC) - Monday, Oct 18, 2004 at 19:42
Thanks Aandy.
339991
Reply By: Lone Wolf - Monday, Oct 18, 2004 at 19:58
"Commonsense tells me I should but I can't find it, which is making me ask myself if it ever existed. "
If a regulator was regulating, and no regular regulars seen it regulating, then regale in the fact that the regulatory statutory requires that regulators shall regulate until regular transmission is resumed regularly. I think....... that's if it existed......
I'm regular.....Wolf
80756
Follow Up By: Lone Wolf - Monday, Oct 18, 2004 at 20:09
In other words.......yes.....
340000
Follow Up By: Member - Spook (SA) - Tuesday, Oct 19, 2004 at 09:47
What are you on??
I want some......
340064
Reply By: Bros - Monday, Oct 18, 2004 at 20:14
Jimbo,
You really should be firing up the Chescold every month or so for a day or so to keep the gases flowing or so i am told. My 40 litre is 12 or so years old and i fire it up every so often, still functioning. IMHO.
Bros.
80765
Follow Up By: Bros - Monday, Oct 18, 2004 at 20:16
Jimbo,
I sometimes run it on 240 for months on end especially around Christmas.
Cheers.
Bros.
340002
Follow Up By: Flash - Wednesday, Oct 20, 2004 at 10:22
Mine is 14 years old, often sits for 8- 10 months without getting used. (I have a 12v compressor fridge which gets far more use.)
Ther is NO need to "fire them up" regularly- just keep it in a clean, dry place. (Block gas line holes to keep insects out)
340244
Reply By: Baz (NSW) - Tuesday, Oct 19, 2004 at 07:14
Do what bros does or use it as a beer fridge they work better if used alot, and if when u turn it on and it doesn't seem to be working properly turn it upside down for 2 or 3 hours (off of course) and it will get it working
well again.
Baz.
80799
Reply By: Bros - Tuesday, Oct 19, 2004 at 08:04
Jimbo,
Have also found the gas jet made up with gunge and after a blow out with air worked perfectly again.
Bros.
80803
