has anyone fitted polyairs to 80 series
Submitted: Monday, Oct 18, 2004 at 22:37
butch
bought some polyairs and reading the fittment instuctions it says to drill a 44 mm hole in the upper coil mount plate ..has anyone done this it seems a big hole for movement of a valve? thanks butch
Reply By: Eric from Cape York Connections - Tuesday, Oct 19, 2004 at 06:36
Butch that does seem rather large.
Could it be 4.4 mm
I would ring the the people who sold it to you.
All the best
Eric
www.capeyorkconnections.com.au
80797
Reply By: Ruffstuff - Tuesday, Oct 19, 2004 at 09:32
Butch,
I recently fitted some firestone coil rite's which are the same as polyairs.
There was no need to drill any holes in the upper coil mount plate.
Once you take the bump stop off, the hole left where the bolt used to be is where the airline is fed through.
the bump stop sits on top of the poly air and is held in place when the coil compresses after you lower the jack.
there are fitting instructions available on www.Trucksprings.com
The only drilling i had to do was for the valve used to inflate the poly airs- it was about 6mm
hope this of some assistance.
80815
Reply By: Member - Don (QLD) - Tuesday, Oct 19, 2004 at 11:57
Butch,
I got
mine fitted by TJM and they do drill a hole that big.i am sure there is a
archive that mentions the install process by another member.
Don
80835
Reply By: Moose - Tuesday, Oct 19, 2004 at 13:32
Yep - they recommend a bloody big hole to allow free movement of the air line. When I found out that I had to drill a hole I took them back. I didn't want to lose the bump stop on a permanent basis as I only wanted to fit the air bags when heading off on holidays fully loaded. I know I could have left them in permanently but I didn't want to.
80847
Reply By: Member - Nick (TAS) - Tuesday, Oct 19, 2004 at 17:36
I just fired up the Gas and oxyed a 44mm ish hole in,no probs.(4 Runner)
80904
