sand spear
Submitted: Thursday, Oct 21, 2004 at 19:20
Justin
Does anyone know anything about these? Where will they work, how much
water can you get out and how fast. Can you attach a manual or electric pump? The property we stay at in the NT has sand everywhere and it is a huge effort to get enough
water for showers from the closest
creek. The river has 5m banks so will there be a
water table under the sand up top?
Reply By: Rick Blaine - Thursday, Oct 21, 2004 at 19:35
Strewth Mate what a question..... so complex but I do have some experience with these... Ok you have to find the
water table it may be some way down... If you live near the sea with deep sand under you sometimes you can drive the spear in with a sledge but that will at best get you 3 metres in soft sand (maybe
water could be found just under the surface in a
sandy creek bed... depends on a lot of factors though)If you hit a rock its game over. Usually these are put down a hole that has been bored with a rig. The quantity of
water and its quality are subject to what is in the ground... The last spear I put down near Nowra gave very brackish
water while one down the road was giving "spring water" and the solution was to go another 5 metres down...Usually you will get best results form a power pump as lifting
water any more than a few feet by
hand pump will be very frustrating. I'm dont think this would be an ideal proposition unless you made it permanent... what about pumping the
water via
windmill to a header
tank from the
creek?
81128
Reply By: Utemad - Thursday, Oct 21, 2004 at 20:43
I camped next to a guy at
Double Island Point - Little Freshwater in January. He had a spear pump operating in his
camp using a 12v pump. I think he said it went down 3 metres. The
water was beautiful.
81142
Reply By: Member - Crazie (VIC) - Thursday, Oct 21, 2004 at 23:10
Hey Justin
We make our own and use then near large dunes and in our
campsite. In our camps we have some down about 12 feet (we made special plunger to suck out the sand) and at the bottom of the dunes about 6 feet for fresh
water. We use sureflo 12v pressure pumps and can spray ab out 10 meters with a hose attached. best
water in the world. I have a drawning on our most recent spear about 5ft long, let me know and i can email it to you. Hardest thing is to find the stainless steel mesh required to ensure no sand get through.
Adam
81171
Reply By: Vince NSW - Friday, Oct 22, 2004 at 07:57
Justin,
This is not going to much use to you due to the increased regulation of explosives, but we had a holiday hut (
Shack) in the 1950's on the central coast of NSW. My Grandfather would drive lengths of 2 inch waterpipe into the sand. (up to 20 ft deep) The pipe had a wooden plug in the end which had a point.
After the pipe had been driven down, a half stick of Gelignit was dropped down which blew the wooden plug out of the end and formed a caven around the end of the pipe.
We used a hand operated chain pump to pump the
water. Overtime the caven woul silt up, so the process was repeated.
As I say, this will not help you as I have no idea where you would get a chain pump these days.
Vince
81189
