exhaust brakes
Submitted: Friday, Oct 22, 2004 at 09:04
Member - ramp
hi all ,
has anyone used an exhaust brake on thier 4wd to act like using rockhopper gears or instead of using a bit of handbrake in a descent in a auto etc.what problems could occur or is it something to look at.
cheers rob
Reply By: Truckster (Vic) - Friday, Oct 22, 2004 at 09:17
One in the club had one, but didnt like it.. he wouldnt expand on WHY he didnt like it, but that was 18mths ago.
IMHO if they were any good, more would use them. But for $1100 that they advertise in 4b mags is a bit rich.. For $1100 you would go rockhoppers and you would be
miles infront. + a Lockup kit from Wholesale Automatics in Bayswater Vic. Our club mag editor has this exact setup with the hoppers and lockup kit, he goes slower downhill than the manuals now.
81202
Reply By: Disco200Tdi - Friday, Oct 22, 2004 at 10:54
A friend of
mine has one on his isuzu diesel landie. Bought all the bits from a truck wrecker for not much (I think about $100). He fitted it himself by cutting and welding it into the exhaust system. There is a solenoid to activate it.
The exhaust then partly fell apart from the increased pressure, it needs to be in good condition.
He now only uses it for offroading where as he would use it all the time before.
Its probably not as good as crawler gears as he now wants to add an underdrive to the transfer case as
HTH
John D
81217
Reply By: Utemad - Friday, Oct 22, 2004 at 12:57
A mate put one on his 45 series ute with a 2H turbo motor. Although he only uses his when towing his drag car. Never takes it off road at all.
81228
Reply By: theshadows - Friday, Oct 22, 2004 at 17:27
as a semi driver ...I'll tell you now ,it wont give the performance you want. In semi's and large trucks the exhaust brake only really gives decent performance over 1500 revs {on a 12 ltr motor}whic is 50 percent of the rev range.Exhaust brakes dont work at idle.
shadow
81256
Follow Up By: Dennis (Mackay) - Friday, Oct 22, 2004 at 19:28
As a user of them in purpose built 4WD vehicles (Army Mercedes Unimog) they DO work at idle.
Absolutely fantastic for crawling down rock ledges etc.
BUT, that is with a dual range gearbox where top speed is around 90 - 110 km/h. So 1st gear is extremely low anyway.
340526
Reply By: Eric from Cape York Connections - Friday, Oct 22, 2004 at 17:32
How are you rob and family.
I remember that that place in the photo.
Did walshey tell you about the week end away.
I think he is keen.
All the best
Eric
81258
Follow Up By: Member - ramp - Saturday, Oct 23, 2004 at 11:52
hi eric,
all is
well, cannot make the weekend due to work,but early next year keen for a weekend at yerranderie/yalwal or maybe pigeon house.michelle has just purchased a onsite van at bendalong so accomodation waits if we go to pigeon house.
cheers rob
340564
Reply By: Crackles - Friday, Oct 22, 2004 at 17:36
We have used the exhaust brake on a Isuzu light trucks off road & found on slippery hills or snow the
wheels tend to break traction up at times. Had better control just by using the brakes. With the increased back preasure we also had a few issues with leaking exhaust manifolds. Craig...........
81259
