Tuesday, Oct 26, 2004 at 14:46
Hi Mick,
I have heard that happen on many air flow sensors, did your father's 3.0TD have an aftermarket airfilter? Also, my understanding of the 5th gear failure was common to all GU models, not just the 3.0TD but as thats 70% of sales it shows up as a 3.0TD problem (all resolved now with longer output shaft - or so I believe!!!).
But understand once bitten twice shy about the 3.0TD. Also fully understand the lack of roadside fix ability with the 3.0TD. Even travelling with a laptop will only perhaps identify the problem, still need the faulty sensor (or whatever) to fix.
The reliability of the old 4.2 is
well proven, however, the new TD6 4.2TD has EGR and electronic control of the
fuel injection pump, whether it has the same reliability of the old 4.2 is yet to be seen (already reports of EGR gumming - common fix is to bypass).
Unfortunately I think all engines will shortly require a laptop and full workshop for even basic servicing. While engine electronics have come a long way, they are still not perfect and certainly have shortcomings out in the bush. But with the price of diesel on a one way trip, manufacturers are going to wring every last drop of performance and economy out of engines and this will mean even more sensors.
While i loved my 1HZ 80, the performance of the 3.0TD certainly makes me never regret changing over. But i would dearly like the proven track record of reliability behind the 3.0TD that the 4.2 has.
Captain
340933
