Thick Black Smoke
Submitted: Monday, Oct 25, 2004 at 15:59
ThreadID: 17296 Views:2174 Replies:5 FollowUps:3
I have put up with the complaints from motorists behind me for long enough (view from in front is fine - dont know what they are whinging about) and after checking out the low cost options such as air filters and edic motorfuel position, I have taken my 2h powered l/c around to the experts. So for all you smoking 2h motor owners on Friday I will give you the verdict as well as the cost
Reply By: Andrew - Monday, Oct 25, 2004 at 22:10
I guess that your diesel fuel injectors are still original ?
AnswerID: 81660
Follow Up By: Davoe - Monday, Oct 25, 2004 at 23:04
wouldnt have a clue (bought 2nd hand 4 years ago) hopefully that is all it is $50 per injector + labour
FollowupID: 340858
Reply By: Eric from Cape York Connections - Tuesday, Oct 26, 2004 at 06:30
Davoe when you do report let us know what area your in and if they were good give the name.
My 2h is a bit smoky also
All the best
Eric
AnswerID: 81676
Reply By: Member - Karl - Tuesday, Oct 26, 2004 at 08:15
Thick black smoke from a diesel usually means that your fuel is not being burnt correctly as the smoke is simply unburnt fuel. Had a similar problem with my my 80 Series and I had the injectors done and the seals on the fuel pump - cost me nearly $1500 :-(
However it fixed the problem and she went well and fuel econonmy improved, so it was worth it.
Hope all goes well with yours.
AnswerID: 81680
Reply By: MrBitchi - Tuesday, Oct 26, 2004 at 08:20
I thought thick black smoke from a deisel was normal..... :-;
AnswerID: 81682
Follow Up By: Davoe - Tuesday, Oct 26, 2004 at 09:06
darn petrol owner who let you on )
FollowupID: 340882
Follow Up By: Member - Jeff M (WA) - Tuesday, Oct 26, 2004 at 11:29
LOL, I'm on my second diesel now and yeah I did too! :-)
It's cool for tail gators, drop the overdrive off and plant your foot to the floor. ha ha.
FollowupID: 340895
Reply By: MAVERICK(WA) - Tuesday, Oct 26, 2004 at 19:25
and let someone else disconnect a bullbag from a diesel exhaust - then tell them there is no water to clean themselves. This is the reason we are getting stuck with over complicated high pressure diesels that won't run on anything other than the cleanest of fuel - a real bitch in the bush. rgds
AnswerID: 81773
