Thursday, Oct 28, 2004 at 22:27
I'll try, Roachie. If any TD engine has had the fueling 'wound up' (and you have noticed some performance improvement), then it must be generating more waste heat. That is, the thermal efficiency of the engine won't have changed much, so if you're getting more kW out of the engine by putting more kW worth of
fuel and air in, then you must also be putting more kW of waste heat into the cooling system.
[The very best, very large capacity, low rpm, marine diesels are at best approaching 50% thermal efficiency - that is, 50% of the energy in the
fuel is converted into crankshaft kW. The rest goes out with the exhaust gases or into the cooling system.]
This, of course, only applies when the engine is working hard - injection pump 'tuning' really only has effect at high load/full throttle. If your engine is still too hot when cruising at half throttle, then you have fundamental cooling system troubles.
The real killer with overfueling is that exhaust gas temperature (EGT) goes to extreme levels (>720 C) within a few tens of seconds at full load/full throttle -
well before the large thermal mass of the block, head and cooling system will register a significant temperature increase. By the time you see the coolant temp gauge rising, your turbo housing, exhaust turbine blade tips and wastegate valve and valve
seat will have been subjected to these extreme temps for some minutes. And the damage is cummulative.
Please don't think I'm being alarmist here to boost sales (I can't keep up with orders as it is, just now). If you have a stock standard TD engine, you're unlikely to suffer from excessive EGT (unless perhaps you tow a very heavy trailer/caravan often in mountainous terrain with a small capacity TD). BUT, if you have had your TD 'tuned' to give better than standard performance and you do not have a EGT gauge, the I think your turbo is probably on borrowed time.
And, if you've spend $1000 plus on performance upgrades, etc., isn't a few hundred bucks for an EGT gauge pretty cheap insurance? As I've said before, you may not like my gauge but if you don't, please go and buy a VDO one or similar rather than nothing at all.
Sorry Roachie, I've gone a bit off-thread here and jumped on my favourite soap-box again...
341309
