Flawless Pajero Hiccups
Submitted: Monday, Nov 01, 2004 at 20:31
Member - Russell B (SA)
SWMBO rang me at work this morning, the Auto pajero won't reverse!! (1999 NL auto V6 3.5l GLS)
The reversing beeper is active and the lights indicate in reverse but nuffing is happening. What did I do to it?
Try putting it into drive then reverse again and let me know I says in panic suggestion. It worked, but what has happened what! what! what!. Into the workshop for a check up, don't want Mr P mucking up towing the new van this week.
Any body had similar Problems?
Reply By: Willem - Monday, Nov 01, 2004 at 21:36
Mum did not leave the handbrake on and omitted to tell you so?
82630
Follow Up By: Member - Russell B (SA) - Monday, Nov 01, 2004 at 21:41
Already paying for that suggestion.
341674
Reply By: Wayne (NSW) - Monday, Nov 01, 2004 at 21:44
Russell,
When was the last time the AT fluid was checked or changed, just a thought. If that happened in a manual it would cost big dollars.
Wayne
82632
Follow Up By: Member - Russell B (SA) - Monday, Nov 01, 2004 at 23:22
Replaced TF 7500 km ago and had major service (120k) last week.
Checked fluid this arvo all ok.
341717
Reply By: Member - Chris M (QLD) - Tuesday, Nov 02, 2004 at 10:13
When it had the major service did they check the auto? If so, take it back and tell em' they broke it...Only downside to that is they will find some excuse to put the blame back on you and bill you a $1,000.00!
Does the auto rely on an electronic sender telling the box you've put it in reverse?
82705
