Spot lights
Submitted: Tuesday, Nov 02, 2004 at 22:14
Martyn (WA)
Forumites,
I'm installing a spot light and a driving light, is there any rule as to which way they go round? Which way performs the best? No doubt the way I've got them will be the opposite way around to the way the majority tells me. Thanks in anticipation for any information recieved.
Reply By: Member - Ed. C.- Tuesday, Nov 02, 2004 at 22:38
G'day Martyn,
Presumably, you mean which side (L or R) should each light be mounted??
I don't think that there is a "right" or "wrong" way of doing it, simply whatever you prefer...
FWIW, I have the distance (spot) beam on the RHS.. closer to the centre of the road.. Others may prefer the opposite..
Regards, Ed. C.
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
82812
Follow Up By: Member - Rick (S.A.) - Tuesday, Nov 02, 2004 at 23:04
me 2
341859
Follow Up By: Savvas - Wednesday, Nov 03, 2004 at 09:09
me 3
341881
Follow Up By: Member - Karl - Wednesday, Nov 03, 2004 at 12:33
Me 4
341904
Follow Up By: Rosco - Bris. - Thursday, Nov 04, 2004 at 20:36
me 5
342082
Reply By: Matt (W.A.) - Tuesday, Nov 02, 2004 at 22:43
Martyn,
I think it’s personal preference, I don’t have that problem as I have a set of Lightforce 240’s, But they are set up with the Flood (Driving) Light on the Passenger Side to light up the Bush on the Verge and
the Spot on My (Drivers) Side for Beaming down the middle of the road. Works for me.
82813
Reply By: Truckster (Vic) - Tuesday, Nov 02, 2004 at 22:50
Yea Im the same as the other 2 blokes...
but thinking of a set of 181's on top of the bar for more side of the road action...
82814
Reply By: Voxson (Adelaide) - Tuesday, Nov 02, 2004 at 22:58
Well i have done the totally wrong thing but it works
well..
A couple of spotties on the bar like normal,,,,,,, both are flood lights,, one for left side of road and other for right,,,,,, and a lightforce240 in the middle for straight down the guts of the road...It is illegal to have odd lights on the front i believe but not a
well known law....
You can see the furry things coming from all angles then...I had hit too many from the right hand side which made me do the lights like that...
82818
Follow Up By: Truckster (Vic) - Tuesday, Nov 02, 2004 at 23:05
yup, you are only allowed legally to have 2x pencil, or 2x spread... and none above the bonnet EG on top of the bar....
341860
Follow Up By: Savvas - Wednesday, Nov 03, 2004 at 09:11
I might be wrong, but I think it's only in Vic where you can't mix the type of beams.
341882
Follow Up By: Member - Chris M (QLD) - Wednesday, Nov 03, 2004 at 16:55
To solve, just run lightforce 240's with adjustable beams, solves all problems, you can have what you want then.
341920
Reply By: Member - Brian (Gold Coast) - Wednesday, Nov 03, 2004 at 08:01
I now have three Ziel lights, ($140 ea from Repco) with a spot in the middle and the
driving lights either side, but previous to buying the third light I had
the spot on the drivers side and the driving on the passenger side.... a few people told me it was wrong, that I should have had
the spot on the passenger side but I couldn't see the difference and found that the setup was great for me!
82847
Follow Up By: Savvas - Wednesday, Nov 03, 2004 at 17:32
How do you find the Ziels, Brian?
I have two of the 210mm jobs, one in broad and one in pencil beam. Go them for $89 each when they were first launched. Pretty good value for a light of their build.
341925
Follow Up By: Member - Brian (Gold Coast) - Wednesday, Nov 03, 2004 at 19:47
Savvas,
Funny story about how they came about.... some fellow clubbies won a pair in the raffle at a meeting.... being good friends, and they already had lightds, they gave them to us. Then my lovel SWMBO gave me a third as a gift and then there were three.
I love 'em! think they're the best lights ever!!! (I am biased!) The
driving lights give a good sideways spread and the pencil beam cuts straight up the road brilliantly!! I think
mine are the 210's as
well..... not sure offhand, but I know they were $140 each.
341936
Follow Up By: Savvas - Wednesday, Nov 03, 2004 at 21:45
I'm really happy with them too.
If you look out for the Repco sales, they often discount them quite heavily. During October, they were selling all the Ziel models at $79 ea, with a free clear cover (and that dumb stone guard).
341951
Reply By: Andrew - Wednesday, Nov 03, 2004 at 09:16
Hi all
Tried a few different combinations and now just run 2 Hella 2000
driving lights. which gives good range and a great spread with no distracting hot spots. We found we can actually see furries further away than before because we are not having to concentrate on the narrow spot beam. The headlights fill in the closer stuff and we have made sure they are also set up properly.
When we ran the super Oscars (one spot, one driving) we tried it both ways and found that
the spot on the left aimed to the edge of the road gave the best furry warning as it lit up the road edge and the grass edges they hide in. Great on the open road but useless in tight stuff as
the spot light was too concentrated and you were relying on one less light for that 'angle' view.
Whatever you run getting the aiming (including height) set up so the light is where you need it is critical. I have jumped in a few mates vehicles with great lights that didn't show up anything because they had never been aligned.
regards
A
82855
Reply By: Rod W - Wednesday, Nov 03, 2004 at 10:20
If you haven't done it already, then checkout David's excellent article on
Driving Lights under Vehicle Requirements.
82862
