GU 5th gear
Submitted: Wednesday, Nov 03, 2004 at 16:27
Homebrewer
G'Day all..this is my first post,I have a question that I hope someone can answer for me. I have a GU Patrol,TD4.2T July 2001 build,the model with the dodgey 5th gear,I bought it new.The question is, when/if 5th gear fails, and if I'm
miles from help,do I keep driving and if so how far can I drive without doing further damage.If it fails in a remote area the nearest town could be hundreds of km's away.Also has anyone had this problem fixed under warrenty,outside of the warrenty period.
Tanks in advace..PETE.
Reply By: Member - Ed. C.- Wednesday, Nov 03, 2004 at 17:07
Aha... Funny you should mention that!!
As I type this,
mine (May '99 build, Td42T) is at the dealer w'
shop having the box stripped... When the 5th went on holiday, I was approx. 270 km from home. (could have been worse, we were on our way home to
Toowoomba from
Birdsville via
Innamincka, towing a 1.5 ton C/T at the speed limit).. Based on reports here & elsewhere, I was given to understand that it's ok to continue to drive the vehicle (in 4th), which I did...
As for getting it fixed under warranty,
well that remains to be seen.. however, at this stage, I am encouraged by the attitude of the service dept. personnel who are "putting it to Nissan" even though they haven't seen the vehicle since new, as I've done all of my own serviceing, though I've kept accurate records of every oil change & everything else done on the vehicle...
The fella to whom I spoke seemed fairly confident that Nissan would "come to the party", though he did say that I may have to meet *some* of the cost...
Any help is better than none, I guess...
Regards, Ed. C.
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
82902
Follow Up By: Mick - Thursday, Nov 04, 2004 at 08:21
We just went through the problem.
My father drove several thousand back from
Adelaide with the gear gone.
Nissan did the job out of warranty but we did have to pay $1200 for worn bearings, gaskets and a 3rd gear that had chipped (nissan didn't want to pay for that)
341986
Reply By: Leroy - Wednesday, Nov 03, 2004 at 17:08
Do a search. You will find that you are still able to drive in 4th. I'd be inclinded to do an oil change to remove as much if any metal particles in the oil asap before driving again. Also Nissan seem to be fixing outside of warranty but I would assume you may need to push a bit and or call head office.
Leroy
82903
Reply By: Peter Guy - Wednesday, Nov 03, 2004 at 17:14
Pete sometimes when you are on your own in very isolated ares you don't have a choice and if your vehicle can be driven then you drive it. In this situation if you have the good fortune to have a choice then it is best for your car to trailer it back to the next town where the fault can be correctly diagnosed.
My understanding of the Nissan 5th gear problem is that you should be able to drive it indefinately until you make it to a workshop using the other gears and when the gear box is repaired the oil and metal sediment is flushed from the box and refilled with new oil.
I hope you don't find your self in this predicament!
For your model it would be best not to use 5th going up hills especially when towing a trailer.
82904
Follow Up By: Member - Chris M (QLD) - Wednesday, Nov 03, 2004 at 17:25
Just to confirm, 5th gear issues have now been solved haven't they in the 03-04 models?
341924
Follow Up By: Leroy - Wednesday, Nov 03, 2004 at 17:46
Chris,
You're fine. I affected models from 1999-2001. I can't remember the months exactly. Was only talking about this on the weekend as my mates is a late 99 model and he's a little concerned. He did find out the exact dates if you are interested.
Leroy
341926
Reply By: Member - Andrew(WA) - Wednesday, Nov 03, 2004 at 20:38
On the subject of 'you may have to put a bit yourself towards the repairs'
Have spoke to a few people about this as to why some dealers will say it's covered by Nissan and others say it's covered ...but...you will need to contribute X dollars.
Aparently, nissan pay the franchised dealers set amounts of money per warranty claim ie..a gearbox may be a 15 man hour job + parts = WHATEVER.
Smaller jobs are less hours + parts = WHATEVER.
So dealers are paid a fixed amount for a fixed job. If it takes longer the particular dealer is out of pocket in man hours.
Apparently, if the dealer thinks there is a likely hood he will run into more hours than he is paid for, you may be asked to fill
the gap. and heaven for bid, there may even be a few unscrupulous people out there who will ask you to contribute even though they are being paid. They just know you will be happy to pay some extra quids when your getting an expensive fix done at little cost to your self.
It's a dodgy business but I guess you know that because you service things yourself?
82917
Follow Up By: Member - Ed. C.- Wednesday, Nov 03, 2004 at 21:41
G'day Andrew,
Thanks for the insight...
If indeed I am asked to pay a *top-up*, I'll definitely ask for an itemised statement... I have no problem *filling in
the gap* in a situation such as you describe.. At this stage, I have no reason to believe that the dealership in question is in any way unscrupulous (but we shall see!)...
The reason that I like to do all my own routine serviceing is that I've always done it since I started buying cars 35+ years ago, & not only am I comfortable (& confident) doing it myself, but I find it far more convenient doing it at my own pace & at my leisure.. Also, I have in fact been employed as a (unqualified) mechanic (early 70's), as
well as being given full responsibility for service/maintenance on large broadacre farming plant during my 20-odd years employed in that industry, so I like to think that I "know a thing or two" about such things...
Having said that, I must say that the fixed cost of certain dealership
services is rather offputting...
Regards, Ed. C.
| Confucius say.....
341950
Follow Up By: Member - Andrew(WA) - Wednesday, Nov 03, 2004 at 21:50
That cost sure is off putting!
I was always under the belief (told by my dealer) unless the car is serviced by a 'registered repairer' kiss your warranty goodbye?
Who knows?
Good luck with your repair anyway.
341954
Follow Up By: Member - Ed. C.- Wednesday, Nov 03, 2004 at 22:33
There would appear to be some conflicting advice re serviceing & warranty...
When I had the car in for the 1000K check-up, I asked the service manager about this (given that there is a section in the owner's handbook on owner serviceing), and he told me that as long as service intervals & fluid specs are as specified by Nissan, and that *genuine parts* are used, no problem... No, I didn't get it in writing, & I didn't have to put it to the test during the warranty period...
It does appear that they are repairing the gearboxes as they break, regardless of warranty.. Cheaper than a full-scale recall, I guess...
Regards, Ed. C.
| Confucius say.....
341961
Reply By: GeroBoof - Wednesday, Nov 03, 2004 at 21:32
Hey Homebrewer
I have just experienced of which you speak
10kms west of
mundrabilla 5th gear dropped out. I spoke to the nissan mechanic in
berri. He said it wouldnt hurt it to drive so I changed the oil in
Berri then spent 4 days off road in the flinders rangers and ventured back to WA across the Anne Beadell Hwy. Was 1600ks from home when it blew and the final ks for the trip was 7400kms so I did 5800ks with no 5th gear. My only cost to have it fixed was $57 for one bearing!
Just my experience and 2c worth
Get out and get Dirty
Gero Boof
82924
Follow Up By: Member - Ed. C.- Wednesday, Nov 03, 2004 at 22:43
G'day GeroBoof,
That's certainly encouraging news from my point of view!!
Regards, Ed. C.
| Confucius say.....
341963
Reply By: Member - John- Thursday, Nov 04, 2004 at 00:31
We have had three of our early GU work Nissans do their 5th gear. All were promptly rebuilt by Nissan dealers under warranty. In fact
mine was nicer after the rebuild. First
sign of failure is discoloured oil...
orange reddish colour.
Driving in 4th is no probs. Try for a complete rebuild because of the potential damage all those bits of metal may have done.
The replacement parts are much stronger and bigger so should help restore Nissan's reputation for good drive trains
JohnS
82953
Reply By: Homebrewer - Thursday, Nov 04, 2004 at 11:48
Thanks for the replys..that puts my mind at rest,looks like I will not be stranded if 5th gear fails,and by keeping an eye on the colour of the oil I may get an early warning....Any idea of the sort of Kms that they fail at..
PETE...
82988
Follow Up By: Member - Ed. C.- Thursday, Nov 04, 2004 at 17:21
Mine has approx. 77 1/2 thou. on it...
As for the early warning oil colour, when I changed the oil at 60 thou, I paid close attention to this, & could detect no abnormality, nor did there appear to be an abnormal amount of metal on the drain plug magnet... An oil analysis may have picked something up, perhaps...
In any case, I'd already spoken to the dealer service dept. about it, & was told "If & when it fails, we'll look at it.. 'till then, just keep driving it" (or words to that effect)...
So I guess if you're changing the oil just before she's about to blow, then the
orange-red colour would be evident, but in my case it was not...
Regards, Ed. C.
| Confucius say.....
342067
Reply By: duncs - Thursday, Nov 04, 2004 at 14:27
Earllier in the post dates of manufacture were talked about.
I spotted one in the local dealeres service dept. a couple of months ago. I asked the mechanic working on it what the prob was. "5th gear" he said "What model is yours?'
Mine is a May 01 and he said I was outside the danger period but not too worry 'cause Nisssan will pick uo the entire bill if it goes.
Now I'm not in a big town and the mechanic is a mate of one of the guys I work with so I am inclined to believe him.
Based on what I was told my camper skips down the road in 5th. If it is going to go I figure the sooner the better.
Here's hoping it don't
Duncs
83002
Follow Up By: GUPatrol - Thursday, Nov 04, 2004 at 16:24
Duncs,
I sent an email to Nissan Australia, (
mine is june 99 build) upon their reply they asked me to send the VIN number (that is the only way to find out they said).
I did and they replied with the all clear.
Apparently at the beginning of the faulty ones there was a mix of good ones and bad ones.
After 2002 however they were all revised and made stronger.
William
342059
Reply By: CMB - Thursday, Nov 04, 2004 at 22:05
PETE,
I have one of the first turbo 4.2's (1999) and had 5 (yes five) 5th gear sets put in. The current set is the updated shaft and 5th gear that will last. The 5th gear set is in a separate sub chamber that will keep most of the metal out of the main box. The old gear is super small and the splining on the shaft is pathetic. I have determined that high torque loads kill the set (ie driving around town at 60 km/hr in 5th etc).
I have a good relationship with my dealer and have paid $0 for everything to date. I even got one set put in in
Adelaide that cost $0. 2 gear sets lasted less than 30,000 and the last one was put in at 120,000 odd Km. I wroe a letter to Nissan and they said to keep the correspondence letters and they would look after me if the problem ever happend again This was on the 4th set and when the updated gear set became available the dealer installed it even before the 4th set failed. Mind you, we put the gear in a vice, the shaft in the gear and turned it with some stilsons - took some effort but this is how close it was to failing.
If you have any trouble $$ wise drop me a line and I'll send you what I wrote. It might give you some ideas.
Regs,
Chris.
83067
