NISSAN PATROL TEMPERATURE PROBLEM 4.2LGQ PETROL
Submitted: Friday, Nov 05, 2004 at 22:35
ThreadID: 17573 Views:6957 Replies:7 FollowUps:0
I AM HAVING A PROBLEM WITHE MY PATROL SHOOTING UP TO 3/4 NORMAL TEMP A TAD BELOW 1/2 WHEN PUSHED AT HIGH REVS 4500-5500RPM MOST OF MY MATES PATROLS DON'T DO WHAT MINE DOES COOLANT AND WATER PUMP ARE FINE DOES ANYONE HAVE A SOLUTION?
Reply By: Shaker - Friday, Nov 05, 2004 at 23:13
Don't have a solution, just some ideas.
Sounds like a water flow problem, so have you checked the radiator internally & externally?
A soft hose could sucking flat?
Minor head gasket leak?
Thermostat not opening fully?
I have Terrano 2 diesel with exactly the same problem, I have checked all of the above & more. I am about to fit a high flow thermostat.
Mine runs fine 95% of the time, but if I work it hard, up goes the temp.
Fuuny thing I towed a CT all through the outback, temp remained below 1/2, soon as we hit the blacktop temp went up to 3/4.
AnswerID: 83194
Reply By: Member - Ed. C.- Friday, Nov 05, 2004 at 23:19
fan clutch???
Confucius say.....
AnswerID: 83195
Reply By: Mark- Saturday, Nov 06, 2004 at 08:34
My GQ did the same thing, it was the fan clutch.
AnswerID: 83211
Reply By: Flash - Saturday, Nov 06, 2004 at 09:12
1. Please don't yell. (Capitals)
2. As others have suggested, your viscous fan clutch isn the single most common cause of overheating. You can NOT test it while stationary. If you don't hear it "roar" when the engine is hot then it is not working.
It can be refilled with fluid- may help- or alternately a new clutch is the go.
AnswerID: 83213
Reply By: Member - Brian (Gold Coast) - Saturday, Nov 06, 2004 at 15:17
Fan clutch.... IMO I found it not worth renewing the fluid.... maybe it was just the guy that did mine didn't do it properly but in any case it cost more in the long run so it would have been cheaper to replace the clutch in the first place.
The other thing is that mine was doing the same thing but mostly without rhyme or reason until we discovered accidentally a loose earth.... obviously it was affecting the gauge!! Hasn't been a problem since!
AnswerID: 83241
Reply By: Member - Jim M (NSW) - Saturday, Nov 06, 2004 at 22:48
how ya going , ive had a patrol for five years now and towed my boat and cars and never rev'd mine over 3200rpm and i drive above the speed limit all the time. when ya rev it that hard it should get hot.
AnswerID: 83304
Reply By: TonyH - Sunday, Nov 07, 2004 at 01:28
Another cheap fix on the viscious hub is to run a couple of tek screws through them. Only recommend it as a limp home measure, makes the motor work harder use more fuel etc.
Have you looked through(the cooling fins) on the radiator to check it's not blocked?
The fact that it cools down when revved (more air being pulled through the radiator) would point to a viscious hub.
But that doesn't mean that that's the problem ;-)
AnswerID: 83314
