Sunday, Nov 14, 2004 at 21:34
David,
Similar to Dean, have had my 2002NM (petrol) since new. Stock standard, it did 13-14L/100km around town. Long driving on bitumen, 12-13L/100km. These figures were achieved using premium ULP.
Since changing the
suspension system (Tough Dogs and coils) and going one size up with the tyres, I'm lucky if I get 610km on the 90L
tank (15L/100km) around town. The mods made it better off-road though. I do a fair bit of mountain trail driving, and the extra clearance and tougher coils helps heaps.
Just had the 75000km which cost $520 including
fuel injection and air-con clean. With a service interval of 15000km and average of $300, it's not too bad. I still remember paying more for my old
sedan which needed service every 7500km!!
I planned for around 10% offroad in the beginning, but when the 4wd bug bit, it bit hard. Around 40% of kms done so far is offroad; plenty of
trails, sand and more sand,
water crossing, dirt and corrugations. Highly recommend the change of tyre tread from standard H/T to more aggressive A/T. The original H/T set lasted 22000km! The second set (A/T) around 45000 but still had 25% of the tread when replaced. I was not comfortable running it down completely. Running on Yoko Geolandar A/T's again. Rotate them every 5000km and it will give you trouble free running. The
suspension change also helps with corrugations. Stock standard, it felt like the Paj was going to be shaken to pieces.
Some squeaks just started to appear around the dashboard, although not loud enough to be annoying.
Driven correctly and sensibly, the Paj can take you to
places most people won't even think they could. Some of the
places I've been to are more suited to mountain goats, but the Paj came through with not too much fuss. Watch out for the air intake during
water crossings!. It is in a stupid place just above the radiator right in front. I don't believe a
snorkel is available for the petrol engine yet, but I could be wrong.
Have fun!...
84347
Follow Up By: david r - Saturday, Nov 20, 2004 at 12:08
Have you got the GLS or the exceed?. Not sure wether to get the auto or manual. Sounds like the Pajero's are not a bad alrounder.
Can you get a dual battery setup in the engine bay, or is it a bit tight.
Thanks for the reply.
343755
Follow Up By: Froilan - Saturday, Nov 20, 2004 at 13:12
I have the Exceed. I drive it home to work and my better half is not a big fan of manual shifters, so I took the auto. It's got the tiptronic shift so you can use clutchlses manual when you need more control. I do not think tiptronic will ever match a true manual though.
I met someone during 4wd training with a DiD model with a twin battery setup. Not too sure about the petrol. The engine bay looks tight enough.
343762
Follow Up By: pjchris - Sunday, Dec 12, 2004 at 18:50
You can get a dual battery setup for the petrol, I believe, but the vapour canister has to be relocated.
347306
