terrano / pathfinder brake master cylinder
Submitted: Monday, Nov 15, 2004 at 14:32
Rob!
Hi all,
I have a 92 terrano and I think I might need a new brake master cylinder. Can anyone tell me if the pathfinder or navara master cylinder is the same?
Or better still, has anyone got access to nissan f.a.s.t., to find out all of the vehicles that share the same brake master cylinder?
Thanks in advance
R.
Reply By: theshadows - Monday, Nov 15, 2004 at 16:58
ohh ...grr i'll load up fast tomorrow and let you know . email me your chassis number.
84459
Follow Up By: Rob! - Monday, Nov 15, 2004 at 17:40
Thanks Shadow
I'm in the process of downloading F.A.S.T. like you said on prevous post but it's REALLY slow. about 5 Kb/s. SO at this rate it'll be ready in 165 hours. (5.5 days) And I'm using my work computer so I'm not too keen about downloading 5 gig of info onto it.
I'll check my chassis number and email it to you tomorrow.
Thanks again.
R.
343225
Follow Up By: theshadows - Monday, Nov 15, 2004 at 19:05
got f.a.s.t up and hogging drive space now so send it when you like.
you plate is the silver one drivers side up near near the firewall .
shadow
343232
Follow Up By: Rob! - Tuesday, Nov 16, 2004 at 09:58
here it is
chassis - WBYD21-085782
R.
343282
Follow Up By: theshadows - Tuesday, Nov 16, 2004 at 12:09
the chassis number is wrong. its a series problem in "wbyd21" the W is wrong would you like to check please . if not under the chassis number is the series number I can use that.
shadow
343289
Follow Up By: Rob! - Tuesday, Nov 16, 2004 at 12:30
hmm...
Had another look. on the plate is this-
TYPE Q-WBYD21
CHASSIS WBYD21-085782
MODEL WBYD21DPKT616
then there's only the trim code and the engine number.
R.
343290
Follow Up By: theshadows - Tuesday, Nov 16, 2004 at 12:48
your model is wrong........
i take it is WBYD21PKTS16
shadow
343292
Follow Up By: theshadows - Tuesday, Nov 16, 2004 at 13:00
by the way what your model code has told me is that the car is a
b-2.7 td motor
y-4wd
d21 - is the series
d- its a 4 door wagon
p- its a se {r3m} 87-93
k - Auto
t - turbo emissions
s13\16 you have 16 but its wrong it should be 15 or 13 series for exterior options.
hope this helps.
shadow
343297
Follow Up By: Rob! - Tuesday, Nov 16, 2004 at 13:27
All that sounds about right-
perhaps the ending is
S13 and not 613 as i had it.
What is "turbo emisions". Does it mean that it's simply with a turbo?
343304
Follow Up By: theshadows - Tuesday, Nov 16, 2004 at 13:48
It means it has emissions rated for the turbo engine. IE it will have an EGR valve and the emissions will be rated on the 1991 diesal exhaust standard of the day.
Its very hard reading katana but ill try to decipher what the s13 outside options are for you.
Going back to your chassis number the "080000" part or its wrong if its "030000" it puts the car back to a late 89 model to early 1990 model.
If you chassis is "050000" it puts your car early 1991 to mid 1991.
if the 080000 is correct but its a fault with F.A.S.T then that might put the car early 1993. but I think that is unlikely. mid 91 sounds more like it.
shadow
343305
Reply By: theshadows - Tuesday, Nov 16, 2004 at 12:44
okies Ive got it down too. profuction for the wbyd21 series ended in about 10\91 at the 072002 chassis more or less so your 080000 chassis wasnt built.
So either you got the "08" part of you chassis number wrong or your car has been rebirthed.
The part number is 46010-v7400. you have to buy the whole master cyclinder including the
tank caps.
that cylinder runs from 08\87-11\94 on all wd21 terrano's vg30 \ td27 motors.
and y30 vg30 motor from 06\85-06\88 cedric's.
good luck on finding a cedric.
shadow
84558
Follow Up By: Rob! - Tuesday, Nov 16, 2004 at 13:02
Thanks Shadow,
Interesting, with the whole rebirthed thing.
Maybe something was dodged up when it was imported from Japan. I double checked the numbers and they are on the plate as I have written them. The chassis number is also on the actual chassis somewhere right? Maybe I'll have a look at that one day when I'm under the car.
Thanks for all that info, and for your time. Now I can start looking for a master cylinder.
R.
343298
