Air Pressure cut off switch, Where to buy?
Submitted: Tuesday, Nov 16, 2004 at 12:20
ThreadID: 17847 Views:6307 Replies:3 FollowUps:2
Hi All
Looking at building a auxilary air tank and was wanting a pressure cut of switch. Anyone got any ideas where to pick one up. I was wanting about 100psi cut off. I have tried Enzed, Pirtek and Beissbarth.
thanks
Ad
Reply By: fozzy - Tuesday, Nov 16, 2004 at 12:31
crazie
try arb-think about$50
not sure if 100 psi
AnswerID: 84553
Follow Up By: Member - Crazie (VIC) - Tuesday, Nov 16, 2004 at 12:35
Its always the obvious one you don't try.
Thanks fozzy, $14.70.
re-start at 80 psi, cust off at 100psi.
cheers mate
Adam
FollowupID: 343291
Reply By: Squire - Tuesday, Nov 16, 2004 at 12:41
Crazie,
There are a couple of options. I went to Trade Tools (Qld) and purchased a pressure switch from an industrial compressor for $30. It's a 240volt job but works well switching my home-made endless air (a couple of Amps for the clutch). The other option that I priced was the pressure switch off an ARB compressor ($40 avail. thru their spare parts). The advantage of the industrial compressor switch is that you can vary the cut-in and cut-out pressures, but the unit is a bit bulky and just takes up more precious space under the bonnet. Depending on what compressor your running you may need to use the pressure switch to control a relay.
Best of luck...
Squire.
AnswerID: 84557
Follow Up By: Member - Crazie (VIC) - Tuesday, Nov 16, 2004 at 12:49
Cheers Squire
I did look at the industrial cut off switches but thought it was too bulk to fit. Thanks for your help, I will trial the ARB one and see how that goes.
thank you
Ad
FollowupID: 343293
Reply By: duncs - Tuesday, Nov 16, 2004 at 23:41
The ARB jobbie is a car Air con cut out switch. restart at 80psi and cut out at 110psi
Local Auto elec should be able to do one for under $20
AnswerID: 84655
