Border Track at Xmas
Submitted: Friday, Nov 19, 2004 at 13:10
GazzaS (VIC)
Hi all. We are heading to
Adelaide (from
Melbourne) for xmas with the family, maybe stopping over in the
Otways on the way over. We thought to do something challenging on the way home - for us at least. A friend has mentioned the
Border Track as a suitable drive. We are new to 4wd'ing and have not done a driving course yet. We are fitting out the Prado 90 TX diesel with gear but will not have the
suspension done by then. Will have the fridge, pack rack etc + tents and the
camping gear. Plan to have the UHF in by then as
Any comments on the toughness of the
Border Track, both in terms of ruggedness and time of year (I understand it can be hot) will be appreciated. Is it suitable to travel alone? Should we have done a course first. I would expect the main problem will be
Sand Dunes (I plan to have a complressor).
Reply By: navaraman - Friday, Nov 19, 2004 at 13:19
I've only ever done section of the
Border Track, usually travelling alone. Theree are usually plenty of other vehicles on the track, at Xmas it will be busy so you'll be OK from that point of view. There are a few big BIG bogholes, most if not all of thses are fenced off now with side tracks around them. They will be dry at Xmas but need to be treated with respect. Tyre pressure around 18psi work for me and
Red Bluff campground is highly recommended. Enjoy.
85002
Reply By: Mad Dog (Victoria) - Friday, Nov 19, 2004 at 13:36
Not a problem Gazza. There's a couple of tough dunes to get over and a few ruts further south but no problem for the Prado and an inexperienced driver. Take it easy and deflate the tyres and yes it will probably be anything from warm to bloodly hot. You will find that 99.9999% is very easy
85006
Follow Up By: Bonz (Vic) - Friday, Nov 19, 2004 at 15:46
Tough Dunes?? Hardest dune I had to get over was when I was towing something?
343686
Follow Up By: Mad Dog (Victoria) - Friday, Nov 19, 2004 at 17:35
You'll keep :)
343715
Follow Up By: Bonz (Vic) - Friday, Nov 19, 2004 at 17:37
And didn't that guy in the HILUX have all sorts of trouble getting over, had to lower his tyres to 4psi just to make it
343716
Follow Up By: Mad Dog (Victoria) - Friday, Nov 19, 2004 at 18:03
It wasn't that hot there Geoff so why the heat stroke.
There was no hilux but I can remember an old 80 or 60 series flying over after lowering his tyres further. I knew I should have dropped
mine lower than 45, would have made that last 10 metres and without having to snatch another gear like some.
343720
Follow Up By: Bonz (Vic) - Friday, Nov 19, 2004 at 18:05
Ask Wazza, I am sure it was a HiLux on skinny tyres, they tried a few times and then lowered their tyres. I stand to be corrected but my recollection is HiLux.
343721
Follow Up By: Mad Dog (Victoria) - Friday, Nov 19, 2004 at 19:36
I thought you were sick today. What are you doing on here hassling people :)
I'll tell you what. Next time you get stuck in the
Otways don't call the national guard again. Call me and I'll haul you out.
343728
Follow Up By: Bonz (Vic) - Friday, Nov 19, 2004 at 21:01
In this household we speak of the .....
otways..... in hushed tones showing due revernce and an acceptable level of fear and respect. Then we go buy electric
winches and diamond shape chains and we get fit for the unavoidable walk out! Yes I am unwell today and this maintains my sanity, correcting your memory of HiLux's on the
Border track.
343734
Reply By: Member - John - Friday, Nov 19, 2004 at 13:41
Gazza, the
Border Track is a great drive, though as you say, it could be very hot at that time of the year. If you check out the maps for the area, you will see that it is one way from North to South in one section. It can safely be driven by your self, in a
well prepared vehicle. You don't need
suspension mods, or a driving course, just sensible driving. Most dunes have a "chicken" track around them if needed. The sand on the dunes is very fine, so let the tyers down a lot, maybe try 18psi first, then maybe a bit lower if needed. I also believe that parts of the track have been upgraded/expanded, which may detract from the experience? Both times I have been down the track, I have camped at the Soutern end. Hope you enjoy it.
85008
Reply By: Stewy - Friday, Nov 19, 2004 at 13:47
Check with National Parks prior good chance it will be closed due to fire bans
85014
Reply By: D-Jack - Friday, Nov 19, 2004 at 17:13
Border Track is pretty easy, even for the inexperienced provided you are doing the section that falls within the conservation
park Pinaroo side (and let tyres down for the
sand dunes) The 30-40 kms South of Bordertown which is out of the
park is a challenge, believe me, I did my clutch and alternator in, not that there will necessarily be much
water in the bog holes (which that side have not been touched and are all accessable) You will need to use common sense and be discerning about what ruts you go into, as I have seen a lifted hilux and standard 80 series (no spare) stuck with 2
wheels spinning in the air. You should take a winch if going alone, or take someone else (with a snatch strap), or give anything hinting of getting stuck/bogged/bottomed out/rolling over a definite miss. I personally don't think the
border track would be much fun, especialy if the temperatures reach 40 degrees plus, but maybe I'm just soft.
85058
Reply By: geocacher (djcache) - Friday, Nov 19, 2004 at 22:14
Just come back from there last weekend and a Hilux in our group had trouble with it's Auto Disengaging Diff so did the whole trip in two wheel drive with 18psi all round. Only got snatched twice.
Granted it was driven like it was stolen a couple of times and there was a bit of moisture in the sand, dry would have been more of a challenge, but it made it and proved a point.
Enjoy the trip. Look out for the hive of bees in the wall of the
Red Bluff loo. Three in our group got stung.
I've gotta ask, why the hell do you ply line a corugated iron dunny if not to give the bees and wasps a 5 star home?
Pack the adrenaline...
Dave
85094
Follow Up By: Member- Peter & Mrs Peter, Lez - Friday, Nov 19, 2004 at 22:45
Dave, which part of the Track did you travel? ie. from---to.
343738
Reply By: tojo - Saturday, Nov 20, 2004 at 16:30
l think you will find that the track is fairly easy these days as all the hard dunes and pot holes that used to swallow cars up have been bypassed.But still not a bad drive l believe.
85163
Reply By: Mike Harding - Saturday, Nov 20, 2004 at 21:13
I did a section of the
Border Track 3 or 4 years ago in August (I think). Nice weather for it at that time of year - bloody hot in Dec/Jan I imagine - it's not too difficult, I did most of it on road tyre pressures in 4WD.
If you decide not to do it consider the
Murrayville Track (runs to Nhill) it's an easy drive and (providing it's not wet) could be done in a 2WD and it does have a few
water points along it and a few pleasant
camp spots (I might just be persuaded to give you the GPS co-ordinates of one - maybe :). There are a couple of tracks off the
Murrayville which are rather more challenging. But don't underestimate that country - in hot weather you could die out there without the right precautions - and I'm guessing you have children? so exercise caution at that time of year.
Mike Harding
85183
