BOOST nanvara?
Submitted: Saturday, Nov 20, 2004 at 11:45
navara02
hey dudes, hi im new here....
got a couple of questions for you diesel gurus , i have a bit of experience with boosting sportscars and stuff and so now being the proud owner of a '02 3 litre turbo navaara naturally i'm looking for a bit more grunt. i know diesels aint like skyylines but hey there seems to be room for improvement here right?
Questions: aps recomends a exhaust and some digital piggyback computer which i think i'll probably do and maybe track down an intercooler this i can all manage, but whats the deal with raising boost on diesles can it be done safely with the factory management or not possible?
any help appreciated.
Reply By: Member -Dodger - Saturday, Nov 20, 2004 at 11:58
Yes the aftermarket boys have computer chips to enhance performance and economy. One such is unichip. Also a mandrel bent exhaust of two and a half inches or more helps. As this motor 3ltr is the same as the GU Patrol it can be tweaked quite a bit however the downside could be that the drivetrain may suffer under the extra power.
Go and have a yarn with the oposite lock people or some other 4wd specialist.
85138
Reply By: sevo - Saturday, Nov 20, 2004 at 14:18
Gday ,
your navara runs 14psi standard, try tunits web site they quote approx 128kw.
Steve
85156
Reply By: TLS - Saturday, Nov 20, 2004 at 19:40
If your ute is a D22 series Navara with the ZD30-TE 3.0 Litre Turbo Diesel 1/2002 onwards have a look at www.safari4x4.com.au for the Safari Dtronic unit part number SD-35.
These unts are simple to fit and increase the Power by 15% and torque by 20%.
These units are sold and installed if required by ARB etc.
TLS
85176
Reply By: navara02 - Saturday, Nov 20, 2004 at 22:55
yeah ok thanx fellas so now i will consider the dtronic and tunit units, so 14 psi standard eh? thats actually a lot higher than i thought it would be...hmmmm that seems very high for stock setup, i wasnt really keen to go over 1 bar....
so this motor came out in the patrol as
well with an intercooler? does this mean i could perhaps find the exact intercooler and piping needed at a patrol wreckers or something and just bolt it straight on i wonder? probably need some bonnet mods i guess, ? is this possible?
also anyone recomend good dump pipe and exhaust place for good $$$$ value in
melbourne area?
cheers dudes...
85206
Reply By: Member - Toonfish - Sunday, Nov 21, 2004 at 09:20
you have a variable vain on the zd 30 which can be tweaked i dont thinks its 14 psi though?
im doing my intercooler at the mo using either a wrx subaru front mounted (due to lack of engine room on top unless i went a body lift, prob using mandrel bends and steam pipe stainless has too much heatsoak.
failing air flow on that a qd32 intercooler from jap imports.
cheers good luck
85228
Reply By: navara02 - Sunday, Nov 21, 2004 at 19:58
sweet, man wanna make up two sets? while your at it ? anywhere near
melbourne?
let me know how it goes anyway :_)
85282
Reply By: navara02 - Sunday, Nov 21, 2004 at 20:24
also how do i lock my front diff cheaply??????????? is there air locker option for 02 navara or lsd for front???
85289
