Boost Mods on a td3.0
Submitted: Sunday, Nov 21, 2004 at 10:03
ThreadID: 17975 Views:2771 Replies:5 FollowUps:2
Does anyone know how i would go about increasing the boost on my 2003 3.0 turbo deisel. I prefer not to go down the option of a unichip or dtronic, my understanding is that these little beauties have electronic controlled fuel pumps that will automatically change fuel pressure depending on how much boost you run. I was thinking of putting a spring on the wastegate so it doesnt open as far.
Reply By: 80scruiser - Sunday, Nov 21, 2004 at 10:44
Your kidding aren't you.
These things have enough problems without stuffing around with them.
AnswerID: 85236
Reply By: awill4x4 - Sunday, Nov 21, 2004 at 11:30
You don't specify what vehicle it's for, but if it's a Nissan 3 litre Patrol turbo diesel, have a good close look at the turbo and tell us all where the wastegate is. lol.
Nissan 3 litre turbo's run a variable vane exhaust housing so no wastegates are used. The variable vane is constantly changing its position as determined by the ecu to control boost pressures.
Regards Andrew.
AnswerID: 85241
Follow Up By: 80GGD - Sunday, Nov 21, 2004 at 16:05
So what do you suggest i do??? i have a 3 inch exhaust straight of the turbo, however i want to run more boost???
FollowupID: 343834
Reply By: Member - Andrew(WA) - Sunday, Nov 21, 2004 at 23:08
I don't know anything about your question but how do find the 3" exhaust?
What differences has it made?
AnswerID: 85304
Reply By: NissanofOld - Monday, Nov 22, 2004 at 18:43
You can change the boost configuration. There's a locking nut on the variable vane diaphram shaft that can be lengthened or shortened to adjust the vane starting pitch. It only needs a very small adjustment (and I can't say which way) and you will change how it reacts. Play at your own risk. The Dtronic is a far better option.
AnswerID: 85432
Reply By: 80GGD - Monday, Nov 22, 2004 at 21:03
So if i can adjust boost how do ajust the fuel to increase diesel into the engine...???
AnswerID: 85462
Follow Up By: NissanofOld - Monday, Nov 22, 2004 at 21:18
You can't as such, but the ECU will do some adjustment itself to compensate for the extra boost, that's why it's got all those sensors. But that's why the Dtronic is so much better, it looks after the lot.
FollowupID: 344011
