Aux Battery Voltage Meter Round 2!
Submitted: Sunday, Nov 21, 2004 at 13:11
Matt (W.A.)
OK,
now that I have realized that I can’t get the Wires for the Aux Battery Voltage Meter through the Fire wall coz the Aux Battery Tray is sitting over it! My next question is. if I tap into the wire running from the Aux Battery to Bosch Plug which powers my Engle will it cause any Problems with the Voltage supplied to the Engle? If you know what I mean?
Reply By: greenant - Sunday, Nov 21, 2004 at 13:31
The answer is NO its only reading voltage
Greenant
85250
Reply By: MrBitchi - Monday, Nov 22, 2004 at 09:16
It will be OK as long as you don't cut the wire. Cutting and adding connectors will cause a potental voltage drop. Cas you connect directly to the back of the Bosch plug?
85336
Follow Up By: Matt (W.A.) - Monday, Nov 22, 2004 at 09:20
Thanks John,
I'll do just that.
Matt
343888
Reply By: John - Wednesday, Nov 24, 2004 at 23:37
Dear Matt
You wont cause any problems with the fridge, but the voltage display will not be acurate as it will include the voltage drop in the wire.
Cheers John
85812
