Lada gear problems
Submitted: Wednesday, Nov 24, 2004 at 10:13
ThreadID: 18055 Views:2358 Replies:6 FollowUps:6
Stop laughing, this is serious. Yes we do own a Lada and have found it to be a great little worker that will go almost anywhere.
We got it for almost nothing 4 years ago as a runabout for kids to learn on and they have done that. It was also a way of keeping them out of the Fronteria and as the Lada is not over loaded with a top speed, they have managed to keep out of trouble on the road.
The problem is it has started jumping out of 5th gear.
Any thoughts as to where in the gearbox to start looking for the cause.
Ok go ahead with all your Lada Jokes.
Vince
Reply By: cj - Wednesday, Nov 24, 2004 at 10:22
I can't help but give these guys a try as they specialise in Lada's.
www.ladaparts.com
AnswerID: 85676
Follow Up By: Vince NSW - Wednesday, Nov 24, 2004 at 10:26
Thanks CJ. We use them for all our parts. Have found them to be great and orders arrive in 2 days at the most. I will give them a call and see if they have any advice. I should have thought about this before.
Vince
FollowupID: 344199
Reply By: Member - Captain (WA) - Wednesday, Nov 24, 2004 at 11:46
Hi Vince
I too used to own a Lada many years ago (very underated performance wise, but not super reliable). I "lost" 5th gear on my box, apparently caused by misalignment problems with the "donut" vibration dampener and causes the nut to vibrate off the shaft. i would get it seen pronto before it costs you big $$$. I had to have the gearbox fixed as well as the "donut" replaced. It was over 10 years ago so my memory is a bit hazy about the exact problem, but i certainly would get it seen to straight away. Probably best to find a Lada specialist as these vehicles have a lot of quirky mechanical items.
Captain
AnswerID: 85686
Reply By: Michael ( Moss Vale NSW) - Wednesday, Nov 24, 2004 at 12:54
OK, so it you who owns the lada!!!!!!
AnswerID: 85698
Reply By: Shaker - Wednesday, Nov 24, 2004 at 15:25
Funnily enough Lada Nivas were rated in the top 10 used 4x4s in a recent 4WD Monthly!
I sold these new back in the late 80s, & the rubber uni joint was always a problem in regards to vibration, usually at around 80kmh. Was an inherent fault that they just couldnt seem to fix. I often wondered if fitting a Fiat rubber uni joint would have fixed it, as they are primarily based on Fiat, with heaps of 125 parts being the virtually same.
They are really quite a capable 4x4 with constant 4wd & centre diff lock.
AnswerID: 85732
Follow Up By: John from River City 4WD Club Inc. - Wednesday, Nov 24, 2004 at 17:48
The main shaft nut on the back of the gearbox loosens off and needs to be checked/tightened regularly so you don't stuff up 5th gear. Get it serviced by people who know Ladas and they'll always tighten the nut up. Similar problem to mid 80's Pajeros I believe and probably others as well.
FollowupID: 344278
Follow Up By: Member - Jeff M (WA) - Wednesday, Nov 24, 2004 at 19:07
And 4 coil suspension to I think?
FollowupID: 344290
Follow Up By: stitch - Sunday, Nov 28, 2004 at 00:49
Bloody 5th gear probs???? did 2 boxes in a 85 pajero due to the nut on 5th gear.
FollowupID: 344806
Reply By: theshadows - Wednesday, Nov 24, 2004 at 20:13
common problem with the fiat 124 5 speed. it the large bolt on the output shaft.if you lucky and nothing is is wrong it might cost you just dropping the tailshaft and transfercase.
If drop out the box and rebuilt it at the same time you get change out of a grand. and second hand box will cost about $250 . Same time as stated get a new donut put in as well be careful on alighment.
to go over board drop the calipers and drop in some brembo 4 pot calipers and a good master cyclinder. mind you the lada ones are a work of art just they feel spongey.
shadow
AnswerID: 85777
Follow Up By: Vince NSW - Thursday, Nov 25, 2004 at 09:24
Thanks every one for the advice.
Shadow, do I have to drop the transfercase to get at the output shaft ?
Vince
FollowupID: 344391
Follow Up By: theshadows - Thursday, Nov 25, 2004 at 18:43
transfer has to be dropped.
its is easier to drop both at the same time then split the boxes apart.
shadow
If you really want to go over board with it a 2.0 ltr double over had cam EFI 1983 124 motor will nearly drop straight in.drop the computer in the glove box. Also move the sapre wheel to an outside location . as for engine mods you just got to modify sump for the front diff housing.
That will give you 3 times the horse power.
FollowupID: 344499
Reply By: Uppy - Member - Wednesday, Nov 24, 2004 at 23:02
Hi Vince ,there is nothing wrong with Ladas, Ive spent time in Russia ,and they are develop for one of the most harsh countries in the world.as for the problem with the box ,sorry I can not help
regards uppy
AnswerID: 85808
