Alloy Rims versus Steel Rims
Submitted: Friday, Nov 26, 2004 at 20:06
ThreadID: 18112 Views:2400 Replies:5 FollowUps:0
I am interested to hear the view of members on the suitability of
fitting alloy rims, in lieu of steel rims, to off-road camper
trailers.
What are the for and against arguments, or should we be indifferent?
Thanks in advance.
Reply By: Member - Jack - Friday, Nov 26, 2004 at 20:39
Hi Landie
If you damage an alloy rim off-road you are sunk, whereas a steel rim can be bashed back into shape with a good hammer. I guess it depends on how "off-road" you want to travel. Alloys are probably OK for 80% of the time, but possibly not encouraged for things like the Canning, or places where rim damage is a distinct possibility.
I guess if you bend or bust an alloy rim you'd probably wish for a steel one.
But there is a nice weight saving with alloys.
Others may have stronger and/or better qualified responses.
Jack
AnswerID: 86056
Reply By: MAVERICK(WA) - Friday, Nov 26, 2004 at 20:49
apart from going with what jack has said above just make sure you can interchange the wheels with your 4wd - makes things a bit easier. rgds
AnswerID: 86065
Reply By: Noosa Bushtrackers - Saturday, Nov 27, 2004 at 19:32
Our caravan has travelled 85,000km in the past 4 years including places like the Gibb River Road and Kalumuru Roads in the Kimberley and rough roads in the Pilbara. All the rims are alloys that have the same stud pattern, and we have never had any problems.
If you drive to the conditions, then you are not likely to have any problems. There are lots of late model 4WD's running around all over the country now using alloys.
Brian
Doing it tuff, Towing a Bushtracker.
AnswerID: 86156
Reply By: Member - Phil G (SA) - Monday, Nov 29, 2004 at 10:08
Times are changing.
Alloys are stronger, lighter and rounder, and cheaper than they used to be, and many serious 4wders are choosing them now without problems.
Main hassle is they scratch easily when offroading.
AnswerID: 86359
Reply By: Gossy - Monday, Nov 29, 2004 at 11:52
Steel all the way. Alloy's are for dropping the kids off at school and looking good.
AnswerID: 86373
