MQ Patrol transfer case stuck
Submitted: Tuesday, Nov 30, 2004 at 12:42
MQDan
Hello,
Just bought an '82 MQ Patrol SWB - only problem is the transfer case is stuck in 2H. Shifter had been previously broken off by the previous owner (or dealer?) who obviously had tried too hard to get it into 4H/L - this has been welded back on but it still wont engage.
Anyone else had this problem?
Reply By: Truckster (Vic) - Tuesday, Nov 30, 2004 at 14:05
If they broke the lever trying to get it into 4wd, I would suggest that something terminal in the transfer case....
Or they welded the stick back on but welded it to something they shouldnt have and its now welded into 2wd!
Take a run to a good 4b
shop get them to have a look, would be easier than diagnosing it from here.
86570
Follow Up By: Mad Dog (Victoria) - Tuesday, Nov 30, 2004 at 14:13
Maybe some numb skull broke it trying to get it out of 4wd...bit of wind up.
345153
Reply By: Member - DOZER- Tuesday, Nov 30, 2004 at 17:10
Have a look on outerlimits4x4 for a second hand one...i know where there is one in a long wheel base t/diesel 4 speed if you want it. This is in
Wollongong.
Andrew
86604
Reply By: Member - Crazie (VIC) - Tuesday, Nov 30, 2004 at 17:42
HI Dan
Mine old MQ patrol desiel had a similar problem. We never figured out what it was exactly, but we dropped the gear box and transfer case out and checked it all out, found it worked when it was out on
the bench,put it back in and worked fine. Something could be out of line. Sorry not too much help there, but a similar experience
Ads
86613
Follow Up By: MQDan - Wednesday, Dec 01, 2004 at 13:07
Thanks everyone for the suggestions,
Just wondering Crazie,
Is it necessary to take the gearbox out to get the transfer case out?
345358
Follow Up By: Member - Chrispy (NSW) - Wednesday, Dec 01, 2004 at 13:12
Lets you do the clutch at the same time :)
345362
Follow Up By: Member - Crazie (VIC) - Wednesday, Dec 01, 2004 at 13:48
Hi Dan
I dont think you have to,but I wanted to see what was locking up my 4wd lever and thought is was best to pull the whole thing out. Doesn't take too long from memory. I have a MQ work
shop memory, I will see if i can find it have a look
AD
345373
Reply By: Member - Crazie (VIC) - Sunday, Dec 05, 2004 at 20:51
Hi Dan
Do you have a diesel?????? I have just found my old work
shop manual, yours if you want it. Please send me an email with your address. acraze@bolle.com.au and i will send it to you
adam
87374
