wind up torsion bars
Submitted: Friday, Dec 03, 2004 at 21:55
ThreadID: 18307 Views:4059 Replies:4 FollowUps:1
Just wondering if i can wind up my torsion bars again as the new bar and winch have dropped the front of my courier. They've been tightened before to get a lift of 25mm but thats now gone. Can i tighten further to get back that 25mm.
And by the way, how are they tightened??
Thanks for any advice guys.
Reply By: Member - Nick (TAS) - Friday, Dec 03, 2004 at 22:01
You can wind em up more but are better off going for aftermarket bars as the original bar will most likely keep sagging.Just fitted OME bars to my 4 Runner and the ride is much better(3"lift).You'll find a bolt head about halfway along your 4by under neath it at the back of the torsion bar,wind it in to get more lift
AnswerID: 87220
Reply By: Banjo (SA) - Friday, Dec 03, 2004 at 22:28
Just a thought......isn't the vehicle body supposed to be jacked up to reduce load on the bars before winding them up ?
AnswerID: 87226
Follow Up By: Member - KG (QLD) - Saturday, Dec 04, 2004 at 23:44
yeah you'd have to be bloody strong to crank them up with the full weight of the vehicle loading up the bars..... if anything you'd probably just shear the bolt?
FollowupID: 346068
Reply By: GO_OFFROAD - Friday, Dec 03, 2004 at 23:20
Winding up the bars wont up the spring rate, only the height, you need to change the T bars to cope with the extra load.
AnswerID: 87232
Reply By: Member - Camper (SA) - Sunday, Dec 05, 2004 at 21:51
According to the latest newsletter from Alltrac in SA you will need a wheel alignment after adjustment to the bars.
Camper
AnswerID: 87384
