cobb cookers
Submitted: Sunday, Dec 05, 2004 at 13:31
Mr Z
hi everyone,
just went down to a new
camping store in
melbourne called anaconda an bought a cobb cooker for $150
so tonight its roast lamb for dinner, i read through the archives and it seems that i should use 8 heat beads, should i put the vegies in at the same time as the lamb?
i'll let you know how it turns out
thanks
Reply By: Member - Nobby - Sunday, Dec 05, 2004 at 14:54
That's good buying. I had a look at one yesterday in Bris and it was $199. I would be interested how yours turns out as it would cost less if I got one from your man and freighted it up here.
87337
Reply By: Noosa Bushtrackers - Sunday, Dec 05, 2004 at 15:11
Don't skimp on the heat beads or the fire lighters, and make sure that they are all burning before you leave it for the half hour or so for the heat beads to change colour. We haven't used ours very often, but I couldn't see why I would need 3 firelighters to start a few heat beads, so only used one and not all the heat beads got going, hence we had to finish cooking in microwave as it didn't have enough heat to
cook food.
SWMBO said that she does it similar to a normal oven, if it is a big piece of meat she puts that in first and then later adds the veggies.
It is one of those things that you have to experiment a bit with, and it is best to do it at home where you have other means of cooking if things don't work out too good the first few times.
87340
Reply By: Lone Wolf - Monday, Dec 06, 2004 at 17:08
Well?????
Share with us..... come on!!
Wolfie
87487
Reply By: Member - Chrispy (NSW) - Monday, Dec 06, 2004 at 17:21
A tip for heatbead lighting:
Only use one firelighter in the middle of the fire area. Place 3 or 4 heatbeads around it. Light the firelighter. Then, using tongs, stack the other heatbeads on top of the first ones you put in to form a pyramid. This way, the heat propagates far more quickly though the stack. Once they are
well and truly underway - flatten the stack of heat beads with your tongs. Ready to
cook!
Intel gathered from decades of heat bead use in Webbers......
87489
Reply By: Mr Z - Monday, Dec 06, 2004 at 18:59
it was a success, next time i'll put the spuds on a bit earlier
the meat was real tender, and the spuds golden brown
cant wait to test it out again this weekend
87500
Follow Up By: Member - Chrispy (NSW) - Monday, Dec 06, 2004 at 19:01
Mr Z - you consider it something that might take over most cooking duties while
camping? Apart from the startup time (and who cares - aren't we away in the bush and don't care what time it is anyway?) is it easy to clean?
346283
Reply By: Mr Z - Monday, Dec 06, 2004 at 19:11
i'll probably only use it for roasts (to start with anyway) so i'll still be taking the rest of my cooking gear when i go
camping
the gas stove/fire is alot easier if you just want to boil
water or
cook a few snags etc...
it was pretty easy to clean the roasting tray is non-stick so that is no problem, the rest i just used a scourer, all cleaned up ok ready for next time
i'd like try a damper out as
well on the weekend, just gotta track down a good recipe
87501
Follow Up By: canpin - Tuesday, Dec 07, 2004 at 21:07
Mr Z
I will be in Melb on the weekend, can u tell me where anaconda are located ?
canpin
346471
Follow Up By: Mr Z - Tuesday, Dec 07, 2004 at 21:26
they're in the outer eastern suburbs
corner of cantebury rd, and bayswater rd, Bayswater
its a fairly big place so it's easy to spot
when i got
mine there weren't too many left so if bayswater is out of your way, it might pay to give them a call ph. 03 8720 4000
good luck
346474
Reply By: Rowler - Monday, Dec 06, 2004 at 21:36
We have one & its great, try the damper recipe in the book. we use coopers pale ale beer & it gives a great taste & the damper is still good the next day, if theres any left that is. just be patient with the cooking times & do things as the manufacturer says in the book & you should be fine.
Some people use metho to
fuel theirs....DO NOT DO THIS!
Cheers Rowler (dave) SA
87525
Reply By: petza - Monday, Dec 06, 2004 at 22:10
hi mr z, you will love the cobb as i have had
mine for nearly two years nad use it all the time, just keep experimenting with it.
87535
