Recall Y61 Patrol 3.0L with Cruise Control
Submitted: Tuesday, Dec 07, 2004 at 19:56
ThreadID: 18391 Views:5945 Replies:6 FollowUps:7
FYI - From Recalls Australia
Nissan Y61 Patrol ZD30 Engine
Date: 06/12/2004
Supplier: Nissan Motor Company (Australia) Pty Ltd
Category: Motor Vehicles
Product Info: Nissan Y61 Patrol ZD30 Engine ASCD (Cruise control) Removal S4002
Defect details: The fitment of the ASCD accessory has been found to be subject to a number of fitment quality issues, the most severe of which may result in the vehicle throttle cable becoming stuck. If this cable becomes stuck, the vehicle throttle may then become unresponsive.
Consumer action: Contact your authorised Nissan Dealer.
Make: Nissan
Model: Patrol Y61 ZD30 Engine
Consequences: The installation of the Cruise Control accessory has been found to be subject to a number of fitment quality issues, the most severe of which may result in the vehicle throttle cable becoming stuck. If this cable becomes stuck, the vehicle throttle may then become unresponsive.
Reply By: Member - Captain (WA) - Tuesday, Dec 07, 2004 at 20:08
Hmmm... where is the Nissan throttle cable on the ZD30 engine? Its all "fly by wire" so how does a "vehicle throttle cable" become stuck if there isn't a throttle cable?
All I can think of is it refers to aftermarket cruise controls like the AP50 where a cable actutator is added onto the pedal itself. I guess the Autron cruise control is not affected as it plugs into the ecu, hence no throttle cable to become stuck.
Captain
AnswerID: 87657
Follow Up By: Member - Jeff M (WA) - Tuesday, Dec 07, 2004 at 20:11
LOL, yeah I was thinking the exact same thing Captain! :-)
FollowupID: 346454
Follow Up By: Bonz (Vic) - Tuesday, Dec 07, 2004 at 20:18
Yer me too, I was wondering how the cable could get caught, or how a cable could be used to connect to the carby.
FollowupID: 346455
Follow Up By: Member - Stillthinkinaboutit - Tuesday, Dec 07, 2004 at 20:28
Sounds like the problem is with some of the dealer fitted units, not sure what brand they are fitting or having problems with.
Obviously if you fitted the unit yourself then it would not be Nissans problem, but it could be yours.
I would say a dealer ( or two ) have had customers coming back at them, probably needing a change of underwear to say the least, or someone has been seriously injured ( or killed ). I would say Nissan is recalling these vehicles to rectify the problem or remove the offending device.
FollowupID: 346456
Follow Up By: Bonz (Vic) - Tuesday, Dec 07, 2004 at 20:50
Nissan fitted mine, the only one they do for the ZD30 is the Autron. So were all the others places I contacted to get the cruise fitted. If Nissan coddled together a cable job they would indeed be checking their undergarments for signs of stress.
FollowupID: 346466
Follow Up By: sevo - Tuesday, Dec 07, 2004 at 21:00
Gday All,
On the pedal itself is the throttle cable they are talking about.
Cheers Steve
FollowupID: 346469
Reply By: Leroy - Tuesday, Dec 07, 2004 at 21:07
I can't remember the brand but they are the same mob that also do the stinger car alarms. There is a cable that atached to the top of the throttle pedal.
Leroy
AnswerID: 87677
Reply By: Member - Raymond - Wednesday, Dec 08, 2004 at 08:18
When buying the 2000 3TD Nissan the dealer had one in the showroom with the "genuine" Nissan cruise control fitted. On inspection the actuator had the cable through the firewall and attached to the pedal, so I guess these are the ones being recalled.
Ray
AnswerID: 87724
Reply By: Leroy - Wednesday, Dec 08, 2004 at 09:28
Called a Nissan dealer today and they knew nothing of the recall and said it prob doesnt affect me as it was published on the web so its prob an international recall. Not withstanding the fact it was on the Australian recall site!!!!
Nissan service....
Leroy
AnswerID: 87733
Follow Up By: Member - Stillthinkinaboutit - Wednesday, Dec 08, 2004 at 10:23
It also states the supplier details as being in Australia.
Supplier: Nissan Motor Company (Australia) Pty Ltd.
FollowupID: 346544
Reply By: Member - Algee (NSW) - Wednesday, Dec 08, 2004 at 11:56
Just contacted my Dealer In Glendale (Newcastle) They no nothing! but they do have a replacement on request of centre console lid due to colour coming off.
AnswerID: 87756
Reply By: Member - Andrew(WA) - Wednesday, Dec 08, 2004 at 15:42
This is a long story but I will try and keep it short. I posted an extensive thread on this issue about 18 months ago but can't find it in the archives.
Anyway, When I bought my Patrol 3.0tdi new in june 2002 I had it fitted with cruise before delivery. Nissan don't (or didn't then) make a factory cruise for the 3.0tdi but used the 'Command' brand system which had a throttle cable from the accelerater through the fire wall to an actuator. How the whole thing works I'm not sure but anyway I had a heap of trouble with it which I brought to the attention of my dealer. They fiddled with it but it was never any good.
I did some home work and found out about the new 'Auscruise' by Autron for drive by wire specific vehicles. I sussed things out and found documentation purporting to be from the 'Command' company that specifically stated that the command systems for drive by wire vehciles are NOT recommended and should not be used for the same reason as set out in this recall notice, and others more serious.
Back then (late 2002) I brought this information and the documents (photocopies) to the attention of my dealer.
The result was...I was told the cruise would be changed ASAP at no cost, to the Autron Auscruise. I was told that the Auscruise could not be fitted without training first so the dealer sent his techie to do the course. I was fitted with the Auscruise about 6 weeks later from memory and it has been joy ever since.
The Auscruise has no wires or cables and talk directly to your ECU making smooth transitions and holds your speed accurately.
The Command system pulls on the accelerater and brings the car up to speed. I'm not shore why but because the cable is not exact as the ECU electronics, it constantly tries to get the speed right by increasing speed and going slightly too fast then adjusting by slowing down and vise vera creating a rollacoaster road.
I know some people have these fitted a swear by them. That's great. Please don't bombared me with "mines great" responses because I know some have been happy. I would suggest however that if Nissan are now offering a recall and changing them to the Auscruise. JUMP and get it done.
I am surprised that it has taken this long for the recall. Many 3.0tdi's would have been fitted with the old cable type since it was first brought to the attention of Nissan. I was told that the information was passed to HQ.
And if your wondering, I have nothing to do with and never have had anything to do with the Autron company or the Command company in any way. Just a concerned consumer.
Finally I would just add that the recall my not be for the Command systems alone but may be for all the non drive by wire units fitted. This information serves only as a information tread in relation to my own experiences and the current recall as stated by stillthinkinaboutit at the top of the page.
AnswerID: 87803
Follow Up By: Member - Andrew(WA) - Wednesday, Dec 08, 2004 at 16:04
I see in another thread posted that Nissan are giving refunds and not replacing the cruise control.
This is probably because of the cost factor to upgrade.
Whether or not you jump up and down and demand the Auscruise is up to you! but it worked for me
FollowupID: 346606
