Waeco CDF-35
Submitted: Monday, Dec 13, 2004 at 11:24
Member - Spook (SA)
G'day
Waeco CDF-35
Don't like to put up another fridge post but I can't find too much info about this product. Just wondering if anyone has had any experience with these and can see any drawbacks as they are only around $650 and use the same Danfoss Compressor as the CF 35 and 40. They don't have any handles but I would mount it via the fixing kit available so that's no big deal. The only difference I can see is the controls seem a little more simple - slider rather than button operation.
Brad
Reply By: David Au - Monday, Dec 13, 2004 at 11:38
Should be no issue with any Waeco fridge.
Don't forget the
Supercheap fridge at $499.00
88473
Follow Up By: Shaker - Monday, Dec 13, 2004 at 17:29
I noticed the other day that the
Supercheap Autos fridge has digital temperature readout.
347407
Reply By: porl - Monday, Dec 13, 2004 at 13:00
I've got the first FF model that came out, 30 or 35L i can't remember. Has never missed a beat. Ordinary insulation is its only drawback but i understand newer models are better. I use it as beer and bait fridge now. Doesn't freeze
water very
well but then i do live in
brisbane where is seems a lot hotter than anything south so my external ambient temp. may have something to do with that.
88492
Reply By: Member - Nobby - Monday, Dec 13, 2004 at 16:56
Auto cheap have the Waeco 35l for sale for $599 in Bris. Mate has one and he is most impressed and I have a small 18l and it also works as it should.
88526
Reply By: Member - Jimbo (VIC) - Monday, Dec 13, 2004 at 18:09
Brad,
One thing to keep in mind is the size. 31 L is not a lot. If you can get by with basics you'll be OK but you may quickly outgrow it if you like to take a few extras.
I like to have enough cold beer, wine for the GLW, a leg of lamb, some cheese and kabana, dip, cold
water, soft drinks, lettuce, tomatoes, bacon, sausages etc.
I couldn't get by with a 39 L and recently went to an 80 L. But I do like to take a lot of stuff.
Depends on your needs.
Jim.
88542
Reply By: ianmc - Monday, Dec 13, 2004 at 18:13
I have had the CF45 for 2/3 years & it works as it should even on freeze & I check it with an internal termometer regularly. The slide controls are OK but maybe the
later button design is better.
They have a deep groove on each side of cabinet to lift it. I wanted to screw handles on it but Waeco would not give me any details on where I may drill it.
Have lately wrapped it ( minus the vented area) in 2" foam & completed a 10,000
km trip to FNQ & it was faultless. I took some frozen veges away & used an ice box
for other stuff, making ice in the Waeco as I went. Didnt bother after I used the frozen stuff.
The lid sysytem counld be better but its given no trouble.
88543
Follow Up By: Member - Jimbo (VIC) - Monday, Dec 13, 2004 at 21:16
Ian,
Be happy with your slide control, I assume it gives infinite adjustment control. The button system is the only let down I have found on my CF 80.
The button does not give me the control I like, but I'm fussy. I would like to find something between 3 and 4 lights running it as all fridge. So I have to swap between the two to get the temp I like.
Maybe I'm being picky. I use a thermometer to ensure it is as I like it ie less than 4 down the food end and 0 to -2 at the beer end.
Geez I'm a pedantic sod.
Jim.
347436
Reply By: rihearn - Tuesday, Dec 14, 2004 at 10:24
I have that exact model and bought it on fridgeshop.com with insulating bag for $595 altogether.
It's a good unit and the slide control works fine. I do wonder if the temperature control slide will loosen over time and then be prone to moving on its own but I guess time will tell on that one.
35 litres is enough for a comfortable 3-4 day
camp trip as long as you don't want to carry beer or wine. If thats what you want a bigger fridge is definitely the way to go.
With the insulating bag the fridge is able to keep the temp at about 5-6C about a third of the way along the temp slide from cold. Thats in ambient temps of about 25C to 30C.
I plan to use another layer of insulation when I'm in warmer
places. I was thinking about bubble wrap!
88649
Follow Up By: Member - Spook (SA) - Tuesday, Dec 14, 2004 at 10:33
Thanks for your reply. Sounds like you got a bargain. How does it go freezing as I may want to do this from time to time, from what you said about the slider it seems as tho it should freeze fairly
In regards to an insulator, I thought about making one out of a $2 reflective windscreen shade which is effectivly bubble wrap with alfoil on the outside.
Thanks again.
Brad
347482
Reply By: rihearn - Tuesday, Dec 14, 2004 at 11:04
It works
well as a freezer. First time I used it I managed to freeze everything inside at about 3/4 of the way along the slider. It was about 20C outside. I didn't mean to freeze everything. I just didn't believe a little fridge could be that effective.
Your insulator sounds like it will work
The only benefit of the waeco bag over a homemade job is that it has tiedown points on it. Though these are a bit dubious and I won't be surprised when one tears off!
88655
