toyota hilux
Submitted: Monday, Dec 13, 2004 at 19:57
ThreadID: 18546 Views:4473 Replies:10 FollowUps:9
Hi everyone just brought myself a 2004 3.0 turbo diesel toyota hilux sr5 and i would like to no how they tow a horse float with 2 horses
Reply By: Utemad - Monday, Dec 13, 2004 at 20:26
hmmmmmmmm.............isn't this the sort of question you should be asking before you purchase the vehicle?
How much does the loaded float weigh? A mate of mine tows a 1.5t trailer behind his Hilux same spec as yours but 2002 model and reckons you barely feel it.
AnswerID: 88578
Reply By: Member - Luxoluk - Monday, Dec 13, 2004 at 21:04
Mine pulled a 15' caravan with no drama. Keep the load off 5th gear and use 4th when under load. I'd check your weights to ensure you do not exceed allowable limits inc. towball weight. The 3.0 TD engine is a good little unit and should do the job. Cheers
AnswerID: 88585
Follow Up By: kozie - Tuesday, Dec 14, 2004 at 19:44
thankyou for the postive in put i hope it does the job it will just pull in under 1800kgs
FollowupID: 347614
Reply By: Willem - Monday, Dec 13, 2004 at 21:45
My mate had a 1999 HiLux 3lt which he had turboed. It went well. Towing wasn't a strain and but it had an overheating problem for a long time. He traded up to a Nissan GU 4.2 diesel a few weeks ago and is as happy as a pig in mud :o)
AnswerID: 88592
Follow Up By: kozie - Tuesday, Dec 14, 2004 at 19:39
hi i tryed the 2004 nissan navara but my head hit the roof so that why i decided to buy the hilux more head room less power but at the end off the day the toyota will last if you look after it
FollowupID: 347608
Follow Up By: Member - Jeff M (WA) - Wednesday, Dec 15, 2004 at 15:08
Willem, they are different motors. The non turbo is a 5L and the turbo is a 1kzte. Ozy versions of the 1kzte should have no overheating probs as they took the second battery out to make room for a bigger radiator.
FollowupID: 347756
Follow Up By: Willem - Wednesday, Dec 15, 2004 at 17:30
Hi Jeff...I take it that the 5L is a typo. Not even the Landcruiser has such a big engine. :o)
FollowupID: 347800
Follow Up By: Member - Jeff M (WA) - Wednesday, Dec 15, 2004 at 17:34
5L is the model number, just like the 2.8L D 's model number is the 3L etc etc.
FollowupID: 347802
Follow Up By: Willem - Wednesday, Dec 15, 2004 at 18:21
Aaahhhhhhh....Clear as mud lol
FollowupID: 347807
Follow Up By: Member - Jeff M (WA) - Thursday, Dec 16, 2004 at 13:03
Yeah it's Crazy, the 2.4L was a 2L, the turbo was a 2L-TE, that all made sense, then from there it went non-sensical!
FollowupID: 347940
Reply By: manson - Monday, Dec 13, 2004 at 22:20
A decent sized float will be minimum 850kg (our extended front float is almost a tonne) then two nags close to a tonne, plus some gear you are going to be well over the two tonne mark. Whats the legal limit for a hilux?
AnswerID: 88598
Follow Up By: kozie - Tuesday, Dec 14, 2004 at 19:41
hi the float is only 750kgs and the horses around 400kgs there not big horses
FollowupID: 347611
Reply By: Member Eric - Monday, Dec 13, 2004 at 22:24
As above . I think it will struggle with 2 horses , I calculate it at 2 tonne also
AnswerID: 88602
Reply By: greghud - Monday, Dec 13, 2004 at 23:43
u will need to be careful as the max tow weight is 1800 kg so i would check it b4 the men in blue do. would probably tow it ok but i wouldnt want to be in it if ur going down hill in the wet and hit the skids.
AnswerID: 88615
Reply By: Member - Jeff M (WA) - Tuesday, Dec 14, 2004 at 13:40
You've got an excellent motor there, you won't have a problem. But yeah if it's a manual only use 5th on flat or cruises or not at all. Otherwise you could premetually wear the gear box.
AnswerID: 88680
Reply By: Member - Brett H (QLD) - Tuesday, Dec 14, 2004 at 19:23
I could be wrong but I think the towing compliance is only 1500kg???
AnswerID: 88736
Follow Up By: kozie - Tuesday, Dec 14, 2004 at 19:35
Hi there it can tow 1800kgs the float is 700kgs and thes horses are 400kg i just wanted some info from people that have towed with the hilux so they can tell me how they go.
cheers kozie
FollowupID: 347605
Reply By: Patrolman Pat - Tuesday, Dec 14, 2004 at 22:44
Here's a thought, why not get the two horses to tow the Hilux. Think of the savings with diesel over $1 a litre.
AnswerID: 88770
Reply By: Member - Brett H (QLD) - Wednesday, Dec 15, 2004 at 23:31
kozie,
I have towed a 1500kg+ cherry picker with a 2002 TD Hilux. It travels ok. With no weight in the ute it feels like it is steering from the rear a little. It is possible that the characteristics of the trailer caused the problem more-so than the ability if the car.
It goes up hills better than my 2H troopy!!!!
AnswerID: 88995
