12v outlet
Submitted: Saturday, Dec 18, 2004 at 11:12
ThreadID: 18672 Views:2694 Replies:3 FollowUps:2
Hi, we have just picked up our 2001 Jayco Swan. I was wondering how you use 12 volt "appliances" within the van? Do I need to pick up on a "hot wire" from the car or is there somewhere in the van to wire up a cigaret lighter outlet?
Thanks, Gary.
Reply By: David Au - Saturday, Dec 18, 2004 at 14:00
Gary you need to run a pair (2) of wires directly from the battery terminals with a suitable 25 amp fuse to the camper. The wires need to be a minimum of 6mm² copper conductor size. A 50amp Anderson plug $20.00 (for both sides) is the recommended and usual plug and socket between the vehicle and the camper.
Normally your camper will be wired for 12vDC lights etc either from an internal battery or from the vehicle through your trailer plug.
Cigarette lighter plugs should never be used for more than 2.0 amps
Over 2.0 amps the Hella type 16mm DIN plug are the preferred option.
AnswerID: 89364
Follow Up By: Mad Dog (Victoria) - Saturday, Dec 18, 2004 at 17:27
Those sockets and plugs are only 8 amps aren't they Oz
FollowupID: 348246
Reply By: muzzgit - Sunday, Dec 19, 2004 at 01:25
I would'nt hook up the "hot wire" to a camper or ANY trailer without a dual battery system. Which also needs to have a suitable battery isolator.
Please tell me you have this already?
I prefer to use two pin plugs, known as "low voltage" or caravan plugs. They look a bit like normal household appliance plugs, but the pins are in a "T" so they can only fit into 12v or 24v plugs.
Muzz
AnswerID: 89426
Follow Up By: spring2097 - Sunday, Dec 19, 2004 at 11:21
Muzz, yes I do have a dual battery system with a piranha isolator. I use a engle fridge in the car wihch I intend to use as well as the fridge [3 way] in the camper. What I need to know is how to use the 2nd battery to run 12v things in van ie: an inverter, lights tv etc when camped by river or in bush etc without 240v
All suggestions appreciated.
Gaz
FollowupID: 348316
Reply By: muzzgit - Monday, Dec 20, 2004 at 01:49
Gazz. David Au is spot on.
Anderson plugs come in many different sizes and are perfect to run straight from ur second battery in the car(fuses or circuit breakers included of course) to your camper for lights / fridge / inverter for a TV or kettle.
A mate of mine who's an auto sparkie soesn't bother with batteries in his camper, he runs everything on 240v thru an inverter, wired directly from his vehicle thru an anderson plug, but he doesn't use many appliances!
He's from the old school, walk around in the dark, as long as you can find the fridge and the bed, he's not worried about much else.
You can also run it to a battery in the camper if you wish.
Like david Au said, don't skimp on the size of the cable, and cigarette lighter plugs aren't worth two pinches of duck poo.
AnswerID: 89519
