1992 GQ Patrol Bad Diesel Knock.
Submitted: Thursday, Dec 23, 2004 at 21:40
Hump
Hey Guys,
Little brother has GQ Patrol, Pulled off head to remove broken exhaust stud on NO.6 cyl, put on correct size head gasket and put back together, now it has a bad diesel knock in it WHAT COULD IT BE?
Reply By: Member - Chrispy (NSW) - Thursday, Dec 23, 2004 at 21:58
Hey Hump
Firstly - what motor..... the 4.2 or 3.0?
Didn't touch anything south of the head gasket?
When you had the head off - did you have it shaved....or just whack it back on? Reason I ask is that normally heads are (hopefully) usually chemically cleaned to remove all carbon deposits in the combusion chambers (and everywhere else) - which if you still have plenty of, then this could cause dieseling and pre-ignition anywhere during the induction stroke.
Did you put the timing chain back on correctly and know that you don't have a timing issue?
90130
Follow Up By: Hump - Thursday, Dec 23, 2004 at 22:07
Chrispy,
The motor is a TD 42 and no nothing else was done to the motor, the head was cleaned up at home but there was no signs of carbon under the head. The correct gasket was obtained from Nissan (no.3). It runs alright at idle but when you give it a good stabbing it knocks bad but if you bring the revs up slow it does not do it. I was wondering how much
fuel is supposed to leak off the injectors as there seems to be no
fuel leaking back?( all this for a broken stud!)
Hump
348875
Follow Up By: Squizzy - Friday, Dec 24, 2004 at 07:55
Hey Chrispy, I don't think they had a 3.0L diesel in '92.
They did have the 2.8L though. I think.
Geoff.
348914
Follow Up By: Member - Chrispy (NSW) - Friday, Dec 24, 2004 at 08:14
Geoff - I was referring to the RB30 petrol 6....... from the Nissan Skyline/VL Commodore.
348916
Reply By: Bilbo - Thursday, Dec 23, 2004 at 22:37
Did you take out the injectors prior to pulling the head off? Or did you leave the injectors in the head whilst you worked on the broken stud?
Bilbo
90144
Follow Up By: Hump - Thursday, Dec 23, 2004 at 22:46
Bilbo,
They Stayed in there mate, it only took 5 mins to drill the stud out once i could get at it. The injectors were all cover up as
well as everything else. We drove it into the shed and it was fine except for the exhaust noise.
Hump
348896
Reply By: Truckster (Vic) - Thursday, Dec 23, 2004 at 22:45
When you say the correct gasket, there are 3 thickness gaskets on the TD42 if thats the engine you have...
When does the knock occur? When you start it, or all the time?
coming from front or back of engine?
Didnt leave something in there did you?
90145
Follow Up By: Hump - Thursday, Dec 23, 2004 at 22:51
Truckster,
No there is nothing in there, the knock devolops if you give it a quick stab at around 2000-3000 rpms. The gasket is the same gasket as the one that come off it a Number 3 the number is marked on the LHS front of the gasket I think 3 = 1.25". The Knock is around the NO 4 and 5 cylinders.
Thanks Hump
348898
Follow Up By: Truckster (Vic) - Thursday, Dec 23, 2004 at 23:44
But not at Idle? so only knocks with a quick stab at 2000-3000...
is it a metallic clunk like piston hitting something, or more of a dull thud?
348906
Follow Up By: Mick - Friday, Dec 24, 2004 at 09:27
Hey truckster, you got a spare 383 chev, your making me excited!!
348923
Follow Up By: Hump - Friday, Dec 24, 2004 at 11:41
Truskster,
It is more of a dull thud!
Hump
348938
Follow Up By: Truckster (Vic) - Friday, Dec 24, 2004 at 12:30
Injectors.... or fuel pump knock then, thats the dull thump you can hear...
348945
Reply By: snowman - Friday, Dec 24, 2004 at 08:21
Check your valve clearances, sounds like a valve hitting a piston to me.
90179
Follow Up By: Member - Chrispy (NSW) - Friday, Dec 24, 2004 at 08:24
Yup - which is why I suggested that you re-check the way you re-installed the timing chain - if you accidently missed a tooth in either direction, you may have valves hitting piston crowns at TDC.......
348917
Reply By: Mick - Friday, Dec 24, 2004 at 09:02
To Chrispy, the td42 dont have timing chains, and to remove the head you wouldnt remove the front gear train, the petrol tb42 had chains.
Did you check the valves after fitting the head, the pushrods will be slightly different lengths (very small) which will put the clearences out.
Could also be a bad injector which will knock when running.
Rev engine up and crack the injector lines to eliminate that problem, the knock will go if that is the problem.
I need an engine for a truck build up im doing, How much!!
90186
Follow Up By: Truckster (Vic) - Friday, Dec 24, 2004 at 09:05
GO WITH A 383 CHEV MICK!!!
348919
Follow Up By: Member - Chrispy (NSW) - Friday, Dec 24, 2004 at 09:09
Ye Gods....!!! Too many Chrissy drinkies and too many late nights.
I completely mis-read the post further up stating that it was a TD, not TB as I assumed.....
Sorry :(
Chrispy
348921
Follow Up By: Mick - Friday, Dec 24, 2004 at 09:28
I had a few too many last night as
well!!
348924
Reply By: Patrol22 (Queanbeyan - Friday, Dec 24, 2004 at 11:34
Hey Hump where is your little Brother? You sure you didn't put him in that mighty 4.2 block and he's knocking like crazy to get out?
90209
Follow Up By: Hump - Friday, Dec 24, 2004 at 12:13
Patrol22
Think i should have, think we have found the problem, don't ask me why but when he pulled the injector lines off he pulled them off individually and when he put them back on he has put 2 lines on the back of the pump wrong, talking to a diesel pump
shop and he said it will run without missing but will knock, when i get
home from work big brother will have to fix it.
Hump.
348943
