Rodeo 2.8 turbo freeplay
Submitted: Monday, Jan 03, 2005 at 12:40
Rowdy1
Just adjusted the tappets on my engine and while I had the air intake plumbing off I gave the turbo shaft a feel for freeplay. Does anyone know the allowable sideways movement at the inlet side of the turbo impeller. I had 0.4mm with the engine cold. Thanks in advance for any info.
Rowdy1
Reply By: ianmc - Monday, Jan 03, 2005 at 13:06
Dunno the numbers but my Triton turbo has a bit of slack and after 240,000kms
makes no noise. Local mechanic says they should last as long as the motor but of cousre that may be an idealistic view.
91088
Reply By: Mad Dog (Victoria) - Monday, Jan 03, 2005 at 13:46
Would that be what they call the "wheel shaft end play" ? I know very little about this stuff but I do have the factory manuals for the TF series
ok
Turbine Model IHI RHB52
Wheel Shaft End Play
Apply a force of 1.2kg alternately to the compressor wheel end and the turbine wheel end
Standard....0.03 - 0.06 mm
Limit....0.09mm
91094
Reply By: muzzgit - Monday, Jan 03, 2005 at 20:18
Hi Rowdy, Just in case you're interested, my mechanic has a 2.8 rodeo, which goes really
well. All he did was put an intercooler on top of the motor with a Jackaroo air scoop on the bonnet, and re-routed the vacuum hose to the turbo, made quite a difference to power and torque. Before this he was as slow as all the other 4cyl turbo 4x4's, but now he leaves 'em for dead. It eats long hills!!
As for the freepay on the shaft, I asked him he said it sounds right.
Muzz
91155
Reply By: farmerandy - Sunday, Jan 23, 2005 at 08:35
Hi guys, I came across this thread from a search. I've got a 2001 2.8td Rodeo that needs a power boost. muzzgit, you don't happen to know exactly how your mechanic re-routed the vacuum hose do you (i presume he has altered the way the wastegate actuates by doing this?). any info appreciated
many thanks
94505
