80 series
Submitted: Monday, Jan 03, 2005 at 21:39
ThreadID: 19043 Views:1993 Replies:3 FollowUps:2
my 80 series GLX factory turbo just droped 200 r p m on idle, no other problems, just idleing slower. truck is 1992 model done 235000 k should i worrey safe driveing mal b
Reply By: Jim - Monday, Jan 03, 2005 at 22:30
Hi mal,
Maybe a breather hose has come loose or developed a crack somewhere. I would check all the hoses on the intake manifold, fuel pump before troubleshooting any further.
Hope this helps.
Jim.
AnswerID: 91189
Follow Up By: Member - Mal B - Tuesday, Jan 04, 2005 at 21:27
THANKS JIM will give it a go safe driveing mal
FollowupID: 349885
Reply By: Kiwi Ray - Tuesday, Jan 04, 2005 at 07:23
Hi Mal B
Is the air con on?
Turn it off let the idle settle then turn it (AC ) on and see if the idle lifts 2 -300 rpm if it does not check the idle up unit on the side of the pump
Ray
AnswerID: 91217
Follow Up By: Member - Mal B - Tuesday, Jan 04, 2005 at 21:33
thanks ray the [ac] lifts the idle ok only fault lower revs safe driveing mal
FollowupID: 349886
Reply By: Member - DOZER- Wednesday, Jan 05, 2005 at 07:59
Change the fuel filter...put some fuel treatment through the tank that kills algai.
AnswerID: 91377
