Wednesday, Jan 05, 2005 at 07:58
Poe
We have a '91 GQ with the RB30 engine. While it doesn't have the power of the 4.2 (possibly...), it has been ultra-reliable. I have installed a Genie header and gotten quite a few extra horses out of it. I have also removed the pre-heater gauze at the base of the carby and gained a few more. A good tune and carby re-build (I paid about $250 for a full rebuild) and it goes very
well. It has 33" BFG muddies and still goes up hills like a rocket - irrespective of what else has been said here. It does need a few more revs for sure... but overall the economy isn't too bad - about 16L/100 on the highway (to
Cooma - all up
hill into the mountains) and anywhere from 25-30L/100 on sand - which all fourbies chew
fuel on. Just as a side issue, I have better success with my 3.0 on sand over the guys in their 4.2's... because I can rev the absolute ring out of the engine up the steep dunes in a relatively low gear - keeping a good head of steam right to the top of most dunes on
Stockton beach's soft sand. Don't keep an eye on the
fuel gauge when doing this however...... :(
Rocky trail performance is not as good as the slower, more torquey 4.2 either. A little clutch slipping to keep the revs (and torque) up is the order of the day. Not too bad, but it can be a problem which leads to another clutch replacement over the life of the vehicle. I have a CenterForce installed in
mine now and it's been better and able to take more abuse than the standard unit.
The only thing that you won't be able to do with any ease is tow a heavy trailer. The engine - while it has a fair amount of (read: adequate) power on its own - it doesn't have a great deal of torque - and needs to be kept spinning. The other factor is the gearbox - which comes out of a Nissan 300ZX. While it is smooth and oh-so-carlike in its shift accuracy and speed, you would have, on the odd occasion, a good chance of stripping 5th gear (O/D) with too much weight on the back....like a heavy (700kg plus) trailer.
Don't write it off as a Nissan mistake - it really is a very good 4WD in its own right. It handles better than the 4.2 (with less weight over the front axle) and accelerates just as hard as the 4.2 on-road given that lighter weight. The RB30 engine is a gem that will probably out-last the chassis..... I'm looking at
fuel injection too.. to overcome a tendancy to empty the carby's float bowl on really long steep slopes. There is a supercharger kit available from
Castlemaine Rod
Shop for the RB-30 as installed in VL Commodores that sounds like an option for me too - as it should lift bottom end performance significantly. The engine itself is perfect for doing perf. mods to as it is so strong.
May be it isn't the right choice for what you need to do, but a good machine nonetheless.
91375
Follow Up By: Voxson (Adelaide) - Wednesday, Jan 05, 2005 at 09:09
I actually agree with everything you have said here.....
My mate gets 16ish litres per 100 in the sticks and about 19 - 20 around town...
And yes these 3 litres are great for
sand dunes,,,, he seems to hold his foot flat in 2nd low at about 5500+rpm and not much stops it....So driven like a race car it performs
well....
But the steeper highway climbs kill it and towing is woeful.....
In rocky steep mountain tracks engine braking is non existant and his Patrol can run away up to 20kmh+ with no brakes where
mine can hold 3 to 4kmh with no brakes....
When we all go away to
Peake which is our version of
Stockton he definately is in the top 1 or 2 climbers but as said before these vehicle really have to be driven...
349930
