285's on a Pajero
Submitted: Sunday, Jan 09, 2005 at 00:40
Matt (W.A.)
Has any one Fitted 285 75 R16's to an NM Pajero? If so what were the Issues?
I’ve had
mine raised with OME Shocks and Springs and am currently Running 265 75 R16's but i want to go Bigger! I realize that the
Fuel Econ will get a little worse but who cares. I'm More Interested to here about any possible Clashes or Rubbing in the Wheel Arches that sort of stuff. I'll post the Same Question on the Vic. Pajero Club
Forum Too but I thought I'd try Here First.
Any comments appreciated.
Reply By: SteveW - Sunday, Jan 09, 2005 at 13:56
Hi Matt,
i dont know about fitting them to pajero but they should look good, a friend was replacing his 275/70/16 on his cruiser (A/T's) and found that the 285/75/16 were about $20-$30 a tyre cheaper! no more convincing nesessary. You should have much difference in
fuel economy because they are the same height, just a lil wider
anyway good luck
Steve
92044
Follow Up By: Matt (W.A.) - Sunday, Jan 09, 2005 at 15:37
Cheers Steve
350858
Follow Up By: Member - Roachie (SA) - Sunday, Jan 09, 2005 at 18:19
G'day Steve,
I could be wrong.......but my knowledge of tyre sizes is that a 285/75R16 is about 30mm larger diameter than a 265/75R16. As I understand it, the calculation is:
***First number is nominal tyre width in mm (so 285 is 20mm wider than a 265)
*** 2nd number is a percentage factor of the height of the tyre from tread level to the rim.
*** the 3rd number is the wheel diameter in bloody inches!!! (talk about mixing measurements!!! LOLOL)
So a 285/75R16's diamter is about 427.5mm + 16 inches
A 265/75R16's diameter is about 397.5mm + 16 inches.
30mm larger diameter. (Approx)
350882
Follow Up By: brett - Sunday, Jan 09, 2005 at 18:41
Nope your not wrong Roachie, your spot on. The 285 is 833mm the 265 is 806mm and the original 70 series are 760mm. So you have an overall increase in diameter of 73mm, that's pretty big, you are definately going to notice the affect in gearing, 4th gear will become 5th and you won't have much pull in 5th. To see if they'll foul on anything just have a look at the clearences you have now and you want at least 15mm to spare.
350884
Follow Up By: SteveW - Sunday, Jan 09, 2005 at 20:57
Well i guess i must be wrong.. i always assumed it was tyre width/profile measurement from the rim to outer tyre/rim size. 73mm is alot bigger, if you want to be sure matt before you do it just measure the height of your tyre and compare it to the height of the tyres your thinking of getting(the tyre guy should show u them before you choose the exact tyre). Remember- if your running difflocks (and presumably LSD) then make sure the spare tyre is the same size- if the spare is 73mm smaller then that could play havoc on your drivetrain - anyone feel free to correct me if im wrong
Anyway, let us know how u go
regards
steve
350897
Reply By: GO_OFFROAD - Monday, Jan 10, 2005 at 10:06
I havent had a good look at tyre size on this model, but had a customer on Sat looking at going to a 265 more suited to touring than the standard rubber, and a quick check of the wheel wells while talking with him showed the mudflap area of the front wheel wells to be the closest point for bigger tyres to rub.
If there is room to "improve" the clearance in this area, I will investigate it when the vehicle comes in to have the tyre choice fitted.
We will be upgrading the
suspension, fitting storage, uhf, and changing the rims for the 4wd tyres also while it is in.
92141
Follow Up By: Matt (W.A.) - Monday, Jan 10, 2005 at 15:58
Thanks GO_OFFROAD,
That would be Great if you could do that for me. I'll also take it to Richards Tyre Power (When i Get a Chance!) and ask them If they Could "Trial Fit" one for me on the Front
351017
