Water Filters
Submitted: Sunday, Jan 16, 2005 at 10:32
GeoffMc
We’re picking up our new camper trailer next month and I’m curious to find out what types of filtering systems you use (if any) when filling your
water tank. I’m familiar with using food grade hose, but got to thinking about
water quality in some of the more remote regions we plan to travel in.
Any and all input would be appreciated.
Thanks in advance ….. GeoffM
Reply By: Member - Russell B (SA) - Sunday, Jan 16, 2005 at 11:02
We alway used a single cartridge
water filter when filling the tanks or when on mains pressure in Caravan Parks.
We use a carbon block innner at .5 micron to minimise giardia and the like, carbon to remove bad taste.
Cost about $100 at Caravan Accessory Stores, cartridges need to be replace every 12months at $40-$50 each.
Living in
Adelaide we even have a Pura-Tap fitted in our kitchen.
Russell
93368
Follow Up By: Member - Roachie (SA) - Sunday, Jan 16, 2005 at 12:19
G'day Russell,
How often do you change the filter/s in your Pura-tap?
352357
Follow Up By: Member - Russell B (SA) - Sunday, Jan 16, 2005 at 13:36
We get Puratap in every 12months and they extend the guarantee, cleva buggers aern't they.
Russell
352383
Follow Up By: Noosa Bushtrackers - Sunday, Jan 16, 2005 at 13:38
Because we have 2 separate
water systems in our van, we have a single carbon filter in the line to the drinking tap, and when we are somewhere that has mains
water we put another single carbon filter with click on fittings each side into the mains pressure line. We bought ours from a local plumbing supplies. We don't bother filtering
tank water that is used for other than drinking.
I think the trick is to fit an additional
tank if possible and only put good quality
water into them, that way you won't have to put sub-quality
water in at all.
352385
Reply By: David Au - Sunday, Jan 16, 2005 at 12:54
Geoff here is a link for
water hose
For filtering I use a Karcher in-line filter in the hose which removes all the particles prior to getting to the
tank. This is a cleanable clear see through particle filter and available from Bunnings etc for $25.95. For the
water filter I use a Jabsco AquaFilta from Bias Boating Cat No. 4910 for $88.90 and the replacement cartridge for $59.95 we change each 1st Jan. The important thing with this filter over most others is that it is impregnated with silver to prevent bacterial growth. This is important as camper filters are not used daily like home
water filters. If you decide on a filter other than the Jabsco AquaFilta make sure it is impregnated with silver.
93390
Reply By: GeoffMc - Monday, Jan 17, 2005 at 20:58
Thanks guys .....you've all been a real help, especially you David.
I found an in-line carbon filter with the silver coated crystals for $85.00 here locally (
Southport, QLD).
Once again ..... thanks,
Geoff M
93659
