2l/3l turbo hulix
Submitted: Friday, Jan 21, 2005 at 12:05
ThreadID: 19648 Views:2034 Replies:4 FollowUps:1
G'day, can any one help me
I'm putting on a turbo from a 2l surf on to my 3l hulix i need to know if the oil return line goes into the sump or do i cut a tee into the vac pump drain, Also which exhaust is better 2 1/2 or 3in?
Reply By: Member - muzzgit - Saturday, Jan 22, 2005 at 01:16
The lack of responses tells me no-one is gonna touch this !!
I'd say you'd be best to see a diesel/turbo specialist and ask them.
Cheers'
Muzz
AnswerID: 94368
Reply By: Tuff60 - Saturday, Jan 22, 2005 at 03:10
Return, if you want the turbo to last, goes to the sump. the return line must be at least twice the internal diameter of the inbound oil line and go down into the sump above the level of oil in the sump. Getting the oil out is very important, as oil flow is only half for lubrication and half for cooling. Oil coolers are great but inspect the lines every service and use quality hose rated for hot oil.
AnswerID: 94373
Follow Up By: Tuff60 - Saturday, Jan 22, 2005 at 03:12
forgot to mention 2 1/2 inch exhaust will be fine, just avoid tight crush bends.
FollowupID: 353345
Reply By: Jim-Bob - Saturday, Jan 22, 2005 at 07:40
G'day 46lux
I've got a DTS unit on my 89 3L and the oil return goes into a tee on the vac drain line. A 2 1/2 pipe is big enough.
The only thing i would look at is vane sizes, the 2l isn't as big as a 3l, so just enquire at a diesel/turbo workshop.
Also when you have it fitted you can increase your fuel supply and timing to increase top end power.
Safe travels
Jim-Bob
AnswerID: 94374
Reply By: 46lux - Saturday, Jan 22, 2005 at 18:16
thanks for your responses
I'm going to go into the sump, I will let you know how it goes
46lux
AnswerID: 94424
