Battery Maintenance??
Submitted: Saturday, Feb 05, 2005 at 15:39
Member - Nobby
Is there a Battery Maintenance (eg Projector 3500) that can be used on Deep Cycle Batteries. I looked at the 3500 but they are only work on CC Batteries.
Reply By: Wok - Sunday, Feb 06, 2005 at 08:15
Nobby,
It depends on your type of deep-cycle battery ie wetcell, gel etc.If you are in no rush, the size[current] of the charger can be small [Ah/10]. I use a Hi-tech 15A from Bainbridge Technology; its a 3 stage charger with Equalisation mode[useful for wetcells]; the type of battery setting is done with DIP switches.
I suggest you look around for an 8A 3-stager as minimum for maintaining 1 battery.
96896
Follow Up By: Member - Nobby - Sunday, Feb 06, 2005 at 14:50
Thanks for the reply. We have two 115a Trojans in Parallel so would probably need the heavy duty model. Any idea how much they cost (Approx)?
355562
Follow Up By: Wok - Sunday, Feb 06, 2005 at 18:46
I think about $385 from Springers..this one has the option of up to 3 batteries[obviously the same model] I am not sure if this is just a convenience thing or there is isolation involved.
It is manufactured in France by Tec-Sup...have a Google
355576
Reply By: Member - John Q (QLD) - Sunday, Feb 06, 2005 at 21:01
Nobby,
Have a look at "projecta.com.au" , they have a 12v, 15amp, 3 stage battery charger suitable for 80 to 300amphr batteries. They are below $300 but you need to look around for a good price.
96996
