80 series brake pads
Submitted: Wednesday, Feb 09, 2005 at 02:28
ThreadID: 20265 Views:2412 Replies:7 FollowUps:1
G'day fellas,
Just wondering which pads are the best for the front on my 80 series. I am looking at replacing the pads preferably with non metallic ones. Toyota quoted me $100 for theirs so before I grab a pair, are there any different ones I should be looking for????
Thanks, Mark.
Reply By: thomo - Wednesday, Feb 09, 2005 at 09:59
Bendix 4wd pads ive been using these for years and have never had a problem.
AnswerID: 97410
Reply By: Rod W - Wednesday, Feb 09, 2005 at 11:53
Agree go the Bendix. The biggest killer of any pad is the grit from mud/sand/dirty water that gets into em.
AnswerID: 97426
Reply By: Outnabout David (SA) - Wednesday, Feb 09, 2005 at 13:02
If you talk nicely you should get the genuine ones down a bit in price. if not contact me.
Be carefull with pads. the genuine ones are matched to the rotor. Not much p[oint in buying a set of "harder"pads anbd then have to prematureley replace rotors.
AnswerID: 97437
Reply By: Member - Jeff M (WA) - Wednesday, Feb 09, 2005 at 13:29
I just put a set of Bendex 4wd pads on the surf, the difference in braking is quite noticable. Mind you the other pads were pretty worn... I had genuines on there prevously.
I paid $52 for my Bendex pads.
AnswerID: 97443
Reply By: Timbobaroobob - Wednesday, Feb 09, 2005 at 18:30
Go the bendix 4wd pads mate, you wont find a better choice for the price and they last a good while too. they wont eat your rotors either
AnswerID: 97513
Reply By: Member - DOZER- Wednesday, Feb 09, 2005 at 19:42
Hi If your 80 series is a 9/92 or later, buy a set of front pads for a 100 series rigid diff (or to be techo...a 105 series) These pads fit straight in and have more pad contact with the disc...in essence they are oblong (instead of tapered down the bottom) and once fitted, (i bought ferado kevlar pads for 60 bux) will give you better braking on the front wheels. Absolute godsend if you have bigger tyres or heavy accessories....
Andrew
AnswerID: 97525
Follow Up By: Member Eric - Wednesday, Feb 09, 2005 at 22:57
I am running the QFM's with the vented dics ,
Stops well now lol . I might try the ferado though next time . would be good to compare
FollowupID: 356126
Reply By: MrBitchi - Thursday, Feb 10, 2005 at 09:43
Maxistop are an australian company making pads for a wide range of vehicles. Half the price of genuine and work fine. Have them on my Pajero and Statesman.
Maxistop
Gheers, John.
AnswerID: 97623
