Thursday, Feb 10, 2005 at 10:27
I have a 96 2.8l diesel.
The fifth gear problem was the earlier model, until Mitsu issued a fix using a heaver bearing. The 2.8l uses the same gearbox as the 3.5l petrol. MItsu lifted the body 20mm to clear the heavier gearbox.
Done 230,000k now without any major dramas. Usual turbo diesel problem of not too much power under 1600rpm. Friends 3.5l petrol has more torque up to 1800rpm.
No chassis problems.
Service interval is 5000k for oil, but filter is supposed to be 10,000 but I do oil filter every 5,000 at $30.00ea.
Fuel filter every 20,000 at $38.00 ea.
Otherwise timing belt/injectors and glow plugs serviced every 100,000.
Good old mechanical
fuel pump that is easy to work on.
No diesel auto available until the new shape and the 3.2l diesel.
No signs of rust yet, fingers crossed. Might be soem there somewhere but I can't find it. Only been on beach 3 times. Have to get the fish oil out again soon.
They run out of steam above the 100k mark since they are low geared, 2750rpm at 100k. Have put bigger tyres on, which also increases top speed, now 155 instead of the old 145. Takes a while to get there though. Why I am called plodder, still slower than friends with faster cars. Fastest time
sydney to
brisbane is 10.5 hours. (Friends have done it faster. Friend used to regularly do it under 10 hours on his RS1000 BMW, or another friends old 327 monaro.)
Generally happy with it as a midsize, reasonably capable (but not highly capable) 4WD. Good tow vehicle. Tows trailer sailer of 2 tonnes quite
well, and a pop top caravan of 1000kg you hardly notice, since you drive by torque, not power.
Have a look at the 3.5l petrol. friend regularly gets only 1 or 2l/100k worse than I do, and with diesel prices, he is ahead of me. Has more power on the highway for overtaking.
97626
