Waeco 35
Submitted: Wednesday, Feb 16, 2005 at 08:16
Kiwi Ray
Hi Folks
On the Waeco 35 there is a switch that is labeled, low - off - high. What are the low and high settings for
Thanks Ray
Reply By: Lone Wolf - Wednesday, Feb 16, 2005 at 08:24
From memory, it is the residual voltage cut off detector.
If your car battery gets too low, the fridge will turn off.
High = let's say 11 volts or something, can't remember.
Low = let's say 9.5 volts or something.....
Off = will run regardless of battery voltage.
Wolfie
98615
Follow Up By: Vince NSW - Wednesday, Feb 16, 2005 at 09:29
Amost spot on Wolfie.
I have just found the instructions from
mine.
"High" cut out at 11.5 v
low" cut out at 10 v
"off " (must be irish) means it's on down to the last little volt
Vince
357028
Follow Up By: scott111 - Wednesday, Feb 16, 2005 at 14:41
On my ccf-35 "off means off no power to fridge"
357073
Reply By: tessa_51 - Wednesday, Feb 16, 2005 at 10:47
"off" - must be made by microsoft
Tessa
98635
Reply By: Kiwi Ray - Wednesday, Feb 16, 2005 at 14:07
Thanks for that info that helps a lot, the booklet that came with the fridge was not very clear as to what the switch does
Ray
98669
Reply By: MRTEE ( VIC ) - Wednesday, Feb 16, 2005 at 20:08
Hi Ray I have the same fridge high is for single battery, and low is used for duel batterys o is for duel as
well, but will run the fridge untill the battery is completly flat they are a great fridge.
98723
