Printing web pages
Submitted: Friday, Feb 25, 2005 at 11:12
Austravel
I've noticed some web pages won't fully print out ie you can read all the text on the screen but when printing you lose 10 to 15mm of text on the right hand side. Any ideas on how to overcome this???
Reply By: Truckster (Vic) - Friday, Feb 25, 2005 at 11:15
Page setup problem by the sound of it.
When you go to PRINT check the settings are A4 and do a print preview if possible.
Which browser and printer?
Is the page in a Frame?
100081
Reply By: fozzy - Friday, Feb 25, 2005 at 11:22
austravel
can copy what u want and then paste onto word doc and then print.
will try what truckster says as same happens for me sometimes.
fozzy
100083
Follow Up By: Truckster (Vic) - Friday, Feb 25, 2005 at 11:25
Yea copying it usually works too... except for images.. :(
358296
Reply By: Member - Geoff M (NSW) - Friday, Feb 25, 2005 at 12:00
I'm assuming you're using Internet Explorer,
Go to File->Page Setup,
Down the bottom of the box are some settings for Left and Right Margins, have a play with them. They'll solve your problem, just can't remember if a bigger or smaller margin is what you need.
After adjusting do a print preview, rather than wasting paper.
Hope that helps,
Geoff.
| Geoff,
100098
Reply By: banjodog - Friday, Feb 25, 2005 at 12:09
The easiest solution is to print the document in "Landscape" rather than the default "Portrait".
Just change the printer settings priot to printing and you'll get it every time.
100101
Reply By: Utemad - Friday, Feb 25, 2005 at 12:40
Anything I want to keep I save as an Adobe PDF file. Then I have a soft copy too and it prints fine.
100111
Reply By: Austravel - Friday, Feb 25, 2005 at 12:42
Thanks all will try the suggestions. I usually copy and put into a word document but some pages won't let you copy them.
Thanks again.
100113
Follow Up By: Gajm (VIC) - Friday, Feb 25, 2005 at 12:48
Is that because some sites have the right click disabled on the mouse?...if so my daughter told me to press Ctrl+C (for copy) and then go and paste to word as normal. Otherwise the margin adjustment that was previously mentioned works, in File, page set up, set them smaller, and save it as the default setting.
358318
Follow Up By: Austravel - Friday, Feb 25, 2005 at 12:50
Thanks will try that.
358319
Follow Up By: Truckster (Vic) - Friday, Feb 25, 2005 at 13:22
Cntl A to select all
Cntl C to copy
Cntl V to paste
358323
Reply By: Nudenut - Friday, Feb 25, 2005 at 14:07
As Truckster says...check your prinetr and page setup settings...else go get some american quarto paper...the yanks paper is wider than ISO metric
100122
Reply By: Pluto - Friday, Feb 25, 2005 at 19:36
Hi Austravel,
If you are trying to print pages from EO (I assume you are, seeing you have brought it up here), there is a printer icon at the bottom right corner of every page. Click on that and EO will reformat the page for printing.
100174
Follow Up By: Gajm (VIC) - Friday, Feb 25, 2005 at 21:45
Ive been a member for a year and never knew about the printer icon, hows that for quick
358382
Follow Up By: iMusty - Saturday, Feb 26, 2005 at 14:46
Doesn’t the fact that EO have written...
"Copyright © 1999 - 2005, I.T. Beyond Pty Ltd. All rights reserved."
mean you can't print the page or even cut and paste it like I just did to write this response.
And besides, give the sponsors their monies worth by revisiting the site to re-read what you need.
You never know when you'll be tempted to buy a TF-08G-12
358424
Follow Up By: Austravel - Sunday, Feb 27, 2005 at 11:45
Thanks Pluto, I've had dramas with a number of sites, thanks for
the tip.
358527
