80 Series 1HD-T adjusting valve clearance
Submitted: Friday, Feb 25, 2005 at 19:07
Twigiee
Howdy All, Whats involved? - I'm unsure of the socket size required for the front crankshaft bolt - can anyone help. Also any tips or pointers from anyone who's tacked this job would be appreciated - thanks
Reply By: Member - Phil G (SA) - Sunday, Feb 27, 2005 at 20:26
Your question suggests that you have no idea whats involved.
These are a shim adjustment and are a best left to a specialist 4wd
shop or diesel workshop who have all the required shims plus the necessary tool to access the shims.
Buy a Gregorys #513 workshop manual and it will teach you a lot about your vehicle.
100397
Follow Up By: Twigiee - Sunday, Feb 27, 2005 at 23:53
Phil, thanks for your response - i now understand why noone replied!
i think my qn was a little misleading. I have the manual and am aware that adjustment requires measuring shim thickness/shim-lobe clearance etc.
I'm mainly interested whether a 'special removal tool' is required or whether the shims can be removed with screwdrivers as the manual suggests, and also size of front crankshaft bolt.
I've mainly worked on petrol engines in the past, and have not come across this arrangement before. From the procedure outlined in the manual it does not appear to be terribly difficult - is it?
Regards,
Twigiee
358590
Reply By: Member - Phil G (SA) - Monday, Feb 28, 2005 at 17:49
The job is difficult. I've done my own mechanical work for 30 years, but won't attempt it - happily pay for someone else with the right equipment to do it properly.
100534
Follow Up By: Twigiee - Tuesday, Mar 01, 2005 at 11:00
Can you recommend a good diesel mechanic in
Adelaide (yes i'm in SA too) who can do this and other work for my 1hd-t?
Thanks for you help,
Twigiee
358792
