Thursday, Mar 03, 2005 at 23:34
Hi SantaAus,
This issue has been raised before, below is a cut and paste from my previous response in thread 14221.
Not only is low sulphur better for the enviroment, its better for your engine! Advantages of low sulphur diesel, apart from cleaner exhaust emissions, include reduced corrosion on pistons/rings/
bore, reduced contamination of oil and improved storage life of diesel. Note that sulphur itself is NOT a lubricant.
The corrosion improvement occurs as previously the sulphur reacted with the
water (combustion by-product) and produced sulphuric acid. This acid aggressively attacks metals as
well as contaminating the oil.
The seal problem is supposedly related to "BUNA-N" and Nitrile seals and is potentially a problem for older rotary injection pumps. In-line injection pumps are not affected as they do not have these seals in contact with the
fuel.
Apparently the sulphur in diesel causes the seals to swell and switching to low sulphur causes the seal to shrink, cracking it. BUNA-N seals that have always used low sulphur
fuel apparently are not affected.
The lubrication issue is caused by the process to used remove the sulphur, as it removes other components that aid lubrication. But refiners are aware of this now and add a lubricant during processing.
Western Australia has had low sulphur diesel since 1/1/2000, when it dropped from 1300ppm to 500ppm. While its a significant (~60%) drop, sulphur is NOT totally removed from the
fuel. As of 31/12/2002 it is ILLEGAL to sell diesel in Australia containing more than 500ppm sulphur. Some refiners (BP/Shell) offer ultra low sulphur
fuel with only 50ppm, but lubricity is maintained with additives.
Many diesel engines used in Europe previously could not be used in Australia because of our "dirty" diesel. The new regs bring us into line worldwide and will enable more high performance diesels to be used in Australia.
The only "losers" with low sulphur diesel were the early users when the lubrication issues were not
well known, along with older rotatry
fuel pumps with the older type seals.
I hope this clears up a few misconceptions.
Captain
101055
Follow Up By: drivesafe - Friday, Mar 04, 2005 at 07:29
Hi Captain, I’ll back you on the bad Australian
fuel verses European high tech diesel engines.
I bought my Rangie 2 months after they were released here and when I took it in for it’s first
services, the dealer told me they had been instructed by LR in Britain that because the Australian diesel was so poor in quality, the onboard engine maintenance monitor had to have a different program installed to allow the computer to make allowances for this bad
fuel.
PS that’s an excellent read Captain.
359090
Follow Up By: Matt H (NSW) - Friday, Mar 04, 2005 at 19:25
It is because of Australias 'dirty diesel' that manufacturers such as Peugeot took so long to introduce the high tech diesel vehicles to Australia. They were not going to take such a risk until all diesel in Aus was compliant.
Thanks for the great explanation Captain.
Matt
359160
