Snatch or Extension??
Submitted: Thursday, Mar 17, 2005 at 18:01
Shaker
I have just purchased a new snatch strap ready for our June Simpson crossing, however, I have an existing strap that I inherited a few years ago (never used), how do I tell if it is a snatch strap or a winch extension strap?
Reply By: slyonnet - Thursday, Mar 17, 2005 at 18:38
Go to your local 4wd
shop and ask/compare with theirs.
Otherwise, I can't recall for sure but one normally got one longitudinal mark in the middle of the strap and the other 2 or 3. That's what a 4wd instructor told me a long time ago to be able to tell the difference. Unfortunately my memory is not that good. I would say the one with one stripe is the snatch strap and the other one a winch extension strap. Anyone heard that one before?
Also my snatch strap is wider than my winch strap. so are they both looking the same or not?
Finally you could try to connect it between two vehicles equipped with proper recovery points and see if it expands or not. The snatch strap should be elastic, the winch strap should not.
Rgds,
Sly.
102811
Reply By: Rod W - Thursday, Mar 17, 2005 at 18:40
Compare it with your new snatch strap. If it looks the same then its a snatch strap. If its thin like you
seat belt then its a winch strap.
102812
Reply By: trolute - Thursday, Mar 17, 2005 at 20:42
just test it.
Attach one end to your vehicle, the other to a tree, or power pole, or something (but not a wheeli-bin!) and very slowly move about 3 or 4 metres. A winch strap will not let you move much, the snatch will stretch and you could probably move at least 5 to 10 metres.
Andrew
102827
Reply By: Member - Phil G (SA) - Saturday, Mar 19, 2005 at 12:27
Snatch strap is usually 9 metres in length. The good ones have a tag with its rating written on it (I guess you've looked) and as sly mentioned have a line down the middle which is meant to tell you whether its past its used-by date.
Winch straps are usually 10,20 or 30 metres, and as Rod says, look like
seat belt material.
For the sake of $50 for a new 8000kg strap, I'd get a new one if I was in doubt.
You are not likely to require it for snatching on the usual Simpson roads; it can always be used as a towrope.
103069
Follow Up By: Shaker - Saturday, Mar 19, 2005 at 19:55
Thanks for all the replies ... I have bought a new snatch strap mainly because I wasn't sure what the old one was. Memory must be failing!
360696
