Gearbox swap.....engine left in gear
Submitted: Friday, Mar 18, 2005 at 17:17
Pembo
Gday everyone,i think i might have made a very stupid mistake here,i was removing my gearbox from my hilux today,got everything off and it is just sitting in place, however i realised that the engine has been left in gear......will this stop me being able to remove the g/box as the engine is still engaged with it? if this is the case is there an easier way to fix it rather than having to put it all back together?
Reply By: gottabjoaken - Friday, Mar 18, 2005 at 17:27
Pembo,
I can't imagine that you have got this far without a workshop manual, or at least a maintenance guide.
Just look at how the shaft splines connect through the clutch and that will answer the question.
No, being in gear won't make any difference.
Ken
102942
Reply By: Rod W - Friday, Mar 18, 2005 at 17:35
"the engine has been left in gear"... " as the engine is still engaged"????
102944
Follow Up By: Member - Ed. C.- Friday, Mar 18, 2005 at 17:41
Maybe it's still runnin' ;-))
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
360570
Reply By: muzzimbidgie - Friday, Mar 18, 2005 at 19:47
I can undestand leaving the gearbox in gear, which wouldn't matter zip anyway, but I didn't know Hilux engines had gears ! (apart from a timing gear).
Just rip it out mate, she'll be apples.
102970
Follow Up By: fisho64 - Saturday, Mar 19, 2005 at 03:35
HA, they dont have timing gears, only belts!!
360642
Reply By: Bonz (Vic) - Saturday, Mar 19, 2005 at 09:01
Also check see if you have
water in the radiator or air in the tyres, both of these will also be problems for you, also check if the radio is on, that can also affect the gearbox removal in the same way as the engine being in gear.
103047
