Toy gloat!!!
Submitted: Friday, Mar 18, 2005 at 20:47
ThreadID: 21336 Views:2387 Replies:1 FollowUps:2
And so I should, like I waited 4 months for this thing to arrive from Canon.
I have got myself a Canon Angle Finder C.
Yeah..... okay...... so what does it do?
Okay, what you do is place this onto the eyepiece on Canon EOS cameras. It's like a little periscope thing, like you don't have to look through the view finder from behind it, you can look from the top, bottom & sides.
Uses? When you have the camera VERY low to the ground, say on a tripod, because you may wish to get heaps of foreground in the shot, you simply set the shot up from above the camera, no more trying to lay flat on the ground to see.
Focusing. It has an inherent 1.25 magnification factor, and with a flick of a little lever, you get 2.5 times magnification. This helps to achieve good manual focus, when lighting conditions, or distance do not allow auto focus. Also allows you to set Hyper focusing through DOF preview, by using the 2.5 times setting.
Now, all I gotta do is save for my 70 - 200 Canon White Lens......
Wolfie
Reply By: Member - Poppy (QLD) - Friday, Mar 18, 2005 at 23:10
Hey Wolfie
Will one of those gizmoes work on my box brownie?
Cheers Poppy
AnswerID: 103012
Follow Up By: Mad Dog (Australia) - Friday, Mar 18, 2005 at 23:17
Didn't the box brownie have a view finder on the top as well. I was just a young boy at the time but it rings a bell. Sounds like Wolfie is bringing the Canon up to Brownie specs
FollowupID: 360625
Follow Up By: Lone Wolf - Saturday, Mar 19, 2005 at 09:09
You are correct Ray.
Box Brownies, well, some, had two view finders. Wheel has turned full circle....
Wolfie
FollowupID: 360652
